Cooling system question
Old May 27, 2004 | 03:09 PM
osetleo's Avatar
On my 94-Max when engine cools down coolant is not coming from the the coolant expansion tank back to radiator. I checked for hermetically sealed connection and air buble in radiator.
Is it the problem with radiator cap, which servers as a valve on that line? Should I replace it?
Thanks for an answer.
Old May 27, 2004 | 04:27 PM
medic's Avatar
you can do a pressure test on the radiator cap...pretty simple and you should be able to borrow the tool from kragens
Old May 27, 2004 | 11:23 PM
stevesmax's Avatar
I had same problem...it was the seal between the top tank and aluminium core of the radiator. It was only weeping a little but it was enough to disrupt the flow of water back to radiator. I agree with Medic, get hold of a pressure tester to pressurise radiator and look for leaks.
Old May 28, 2004 | 07:22 AM
osetleo's Avatar
Guys, thank you for ideas.
BkGreen97
Apr 2, 2016 05:47 AM
TheMafia
Sep 4, 2015 08:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
coasterswim
Sep 2, 2015 07:43 AM
A32goldylocks
Sep 2, 2015 06:39 AM
