steering wheel
Old May 30, 2004 | 06:32 PM
xnyc's Avatar
steering wheel
i was wondering wat all the possible factors contributing to my problems could be. my steering wheel shakes really hard wen im going about 65+. i did a trouble shoot search on autozone.com and this is the list.
1 Inspect MOTOR MOUNT Loose or broken motor mount.
2 Inspect EXHAUST SYSTEM Damaged or restricted exhaust system components.
3 Inspect CV HALFSHAFT (REMANUFACTURED) Dry,Worn or damaged cv half-shaft
4 Inspect ADJUSTING SLEEVE Improperly aligned adjusting sleeve or other steering component.
5 Inspect TRANSMISSION MOUNT Loose or broken transmission mount.
6 Inspect TIE ROD END Loose, worn or incorrectly adjusted tie rod end(s).
7 Inspect STEERING STABILIZER BRACKET Loose or broken steering stabilizer bracket
8 Inspect PITMAN ARM Worn pitman arm or other front end part(s).
9 Inspect IDLER ARM Worn idler arm or other front end part(s).
10 Inspect BALL JOINT - LOWER Worn or damaged lower ball joints
11 Inspect BALL JOINT - UPPER Worn or damaged upper ball joints.
which one is the most common on 3rd gens?
Old May 30, 2004 | 06:52 PM
boosted3rdgen's Avatar
of all those things listed it could be the most simple of solutions....the wheels may not be balanced
Old May 30, 2004 | 07:12 PM
Cliff Clavin's Avatar
Way out West
the tires could have uneven wear, too.
Old May 30, 2004 | 07:37 PM
Yourself
also could be a bent rim or LOOSE LUGNUTS or uneven tire pressure ... when the wheels are off the ground SAFELY SUPPORT THE CAR try to wiggle the wheels (grab top +bottom of wheel )+notice any movement ='s bad ball joint or wheel bearing
Old May 31, 2004 | 05:27 AM
internetautomar's Avatar
mod or sell?
I'm gonna say balance the wheels.
While a bent rim won't neccesarily show up on the balance, it will also cause that shake, as well as a broken belt in the tire.
When was the last alignment?
Old Jun 1, 2004 | 05:22 PM
xnyc's Avatar
not really sure wen alignment was but hopefully it has to do with the tires cuz i already got new rims and tires so maybe it will go away wen i put new stuff on. dint notice until a few days ago wen i was on highway and i just got the car from my mom cuz i turned 16 and havve permit
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
