Alternator Removal
Old Jun 8, 2004 | 04:05 PM
jayx27's Avatar
Alternator Removal
Does anybody know where i can find a write up on how to remove the alternator from the '92 SE maxima... I had done it to my old '90 GXE with my dad, but this one seems to be a lil' different... Thanks
Old Jun 8, 2004 | 06:36 PM
jayx27's Avatar
anybody? any info would help... thanks again
Old Jun 8, 2004 | 06:45 PM
«§»Craig B«§»'s Avatar
should be very similar
check out www.4dsc.com/articles for the writeup on the underdrive pulley and also the article on alternator replacement (it's for a VG)
between those you shouldn't have any problems
Old Jun 9, 2004 | 01:33 PM
Minty91GXE's Avatar
i just did an alternator swap and it was suprisingly easy.
- disconnect the battery entirely
- remove the splash shield
- remove the electrical connections, all found on the left side of the alternator. mark where on the alternator (maybe with a sharpie) the connections were, as well as which wires go where.
-at the top of the alternator, you will find two bolts, loosen these, but dont take them off yet.
- the tension bolt is found in a slot at the bottom of the alternator, which controls what angle the alternator sits at, which determines the belt tension. make a mark where the bolt is... then remove it.
- remove the bolts at the top of the alternator (watch out here, you don't want an alternator in the face)
- the alternator should still hang on there, a good tug should bring it right off though.
i did the swap with a socket wrench and two bits, nothing else... it all took less than an hour total.
-Minty
...woops, this is for a gxe. oh well
TallTom
57
Oct 14, 2025 05:16 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
