Is it security system?
Old Jun 9, 2004 | 11:15 AM
boywing's Avatar
Hi,
I replaced all fuel injectors in my 92 Maxima GXE. The engine run for several seconds then died and never start again (engine rotates but will not start). The mechanic found there is no power coming to fuel injector. He said it could be the security system blocking starting. Could anybody tell me if it's possible and how to disarm the security. I tried to input the code again and again. I can roll down the window with the code.
Old Jun 9, 2004 | 11:34 AM
internetautomar's Avatar
mod or sell?
Module?
it isn't the security system, that keeps the car from starting (cranking)
Old Jun 9, 2004 | 04:20 PM
boywing's Avatar
Thanks. The mechanic is still working on it. Still no luck.
Just wondering why the problems with my Max is so complicated.
Old Jun 9, 2004 | 04:36 PM
Matt93SE's Avatar
STFU n00b!
replaced? did he replace the injectors with the proper ones? there are high and low impedance ones. If he used the wrong ones, then it's possible that the computer is fried.
Old Jun 9, 2004 | 05:24 PM
boywing's Avatar
I think they did it with the right ones. They ordered by OEM #.
The reason I changed the injectors is hard, if not no, start. They said it is because of the bad injectors. But after the work, problem is still there. Can anybody figure out anything from the fact that no power coming to fuel injectors? Thanks.
Old Jun 9, 2004 | 05:36 PM
boywing's Avatar
I replaced spark plugs, fuel filter.
Battery is fine.
So what could be the problem?
They also found the spark plugs are not wet.
Old Jun 9, 2004 | 07:30 PM
Matt93SE's Avatar
STFU n00b!
they won't be wet if you're not getting any fuel to them.
are you sure it's the injectors and not the fuel pump?
turn the ignition on, and SLOWLY crank the engine by hand by sticking a bigarse socket (27mm) on the crank pulley and have someone up top listen for the injectors to fire as you turn the engine. if you don't hear any clicking (about three per turn), then the injectors aren't working- fried ECU possibly.. if you DO hear the clicking, then check fuel pressure.
Old Jun 10, 2004 | 08:58 AM
boywing's Avatar
Thank you, I'll check it. Anyway, what's ECU fried? Big problem?
Old Jun 10, 2004 | 09:21 AM
boywing's Avatar
They unplugged fuel filter. Fuel pumps out when crank the engine. They think fuel pump works fine. They are trying to figure out why no power coming to the injector.
I read a lot posters recently about Maxima's hard, or no, start, seems it's not uncommon with Gen 3. But nobody came out with a solution.
Old Jun 11, 2004 | 06:37 AM
boywing's Avatar
Would anybody please tell me what's ECU fired? Thanks.
Old Jun 11, 2004 | 08:06 AM
mod or sell?
ECU fried means that it is no longer capable of sending the signal out to the injectors in this case.
Sounds to me like you need to find a better shop.
Old Jun 13, 2004 | 09:16 AM
boywing's Avatar
OK, the greedy dealer will be happy.
Old Jun 13, 2004 | 05:06 PM
mod or sell?
I NEVER said the dealer, there are a few competent shops out there who have the knowledge to diagnose the car as well as if not better than the dealer.
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
