Tranny
Old Jun 10, 2004 | 12:01 AM
Jack.'s Avatar
Tranny
Wow, my car is freaking me out now. Out of nowhere today, i pull forward from a stoplight, my car goes into second then in second it throws the RPMs in the 5000's out of no pressure on the gas and then finally shifts into third, third is climing and staying steady then does the same thing again but closer to 6500 this time. Is this a slipping tranny?
1990 Maxima Se Automatic
Old Jun 10, 2004 | 08:24 AM
eric93SE's Avatar
First thing is to check the fluid level. If the fluid is old, then do a drain/fill.
Old Jun 10, 2004 | 11:59 AM
internetautomar's Avatar
mod or sell?
Has it done it more than once?
Old Jun 10, 2004 | 03:42 PM
Jack.'s Avatar
Yesterday was the first day it happened. The fluid level, when i checked it was a little low, but not vital. I refilled it after work just to see if there was any noticeable difference. Still slipping really bad and there is no difference whatsoever. I'm not possitive if a drain/refill will be any different. Any idea of the prices if i do the labor myself?
Old Jun 10, 2004 | 05:19 PM
mod or sell?
what color was your fluid?
Old Jun 10, 2004 | 08:42 PM
Jack.'s Avatar
Well, when i checked the level the first time, the fluid was more of a clay red color. Wasn't fresh out of the bottle deep red, but it wasn't black either. When I had the place down the street from my work put some in, I drove around the block, came back and checked it. The color that time was a burnt red as if it either mixed in with the old or got burnt from the tranny. I'm taking the car to this transmission specialist by where I live and having it checked up. From the diagnosis there is where i find my options
Old Jun 11, 2004 | 05:19 AM
mod or sell?
sounds like grilled tranny for lunch
Old Jun 11, 2004 | 06:51 AM
eric93SE's Avatar
Well you shouldn't be waiting for black ATF to change it, changing ATF is easier than doing an oil/filter change. Also check that that the shift bushings are in place, there one where the cable meets t he tranny and one under the heat sheild above the cat convertor for the shift selector. If you have the FSM you could follow their trouble shooting and running the tranny diagnostics. There could be something simple like the TPS or the tranny solenoid pack.
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
