Blank, slotted or cross drilled?
Old Jun 11, 2004 | 02:54 PM
90maxgxe's Avatar
Blank, slotted or cross drilled? I am buying new rotors and need some recommendations. also I found a place that sells the rotors painted, will this hurt
the performance of the rotors?
Old Jun 11, 2004 | 02:59 PM
Jeff92se's Avatar
I'm needing a caw
http://forums.maxima.org/showthread.php?t=314573
Old Jun 11, 2004 | 07:41 PM
thumpyls's Avatar
i dont like drilled.. they crack and are over priced.. go with oem cause u have abs right?just get a better quality brake pad
Old Jun 12, 2004 | 04:16 PM
90maxgxe's Avatar
What about Brembo cross-drilled rotors, do you think those would crack?
Old Jun 12, 2004 | 04:25 PM
Creedence85's Avatar
I think it all depends on the type of driving you're doing. The primary purpose of slotted rotors are increased cooling, and cross drilled are great for reducing unsprung weight. Cooling helps you in hard and extended braking situations, like hilly highway driving, racing etc. and reduction of unsprung weight helps with improving handling. If you aren't looking for either of these with brakes, then I wouldn't go to the extra expense of slotted or cross drilled. Also, I'm not 100 percent sure about cross drilled, but slotted can not be turned. If you do lots of driving, depending on the cost of rotors, you can have the brake rotors turned every couple or 3 pad changes, if you're doing lots of brake jobs, and save some money.
Also, most high performance brake packages that are cross drilled and/or slotted also come with higher performance brake pads, made from harder materials, that while increasing brake performance icrease rotor wear as well. Now, you have a more expensive rotor, that can't be turned on brake lathe, and will require replacment more often. So really, as I said above, unless you need the extra performance, go with the suggestion before me of better pads, then at least, you can turn the regular rotors when they need it, or if they need replacing, do it with a cheaper part.
Brembo is a pretty good name, they're also used on the G35 as OEM for the upgraded brakes, and I've never heard of them cracking, however that doesn't mean that they won't. Chances are if they cracked early in life, there'd be a warranty so I wouldn't worry about that.
Old Jun 12, 2004 | 04:32 PM
goon9's Avatar
Mucho info thanks!
Old Jun 12, 2004 | 04:56 PM
MrGone's Avatar
I like blanks because Matt tells me to like blanks
Old Jun 12, 2004 | 06:53 PM
internetautomar's Avatar
mod or sell?
Painted rotors!
I just made a comment about that on another thread, but anywho
Unless you are doing a big brake upgrade get a nice set of brembo blanks and be done with it.
They'll last longer , and stay cooler than a set of drilled rotors will.
and most brembo drilled rotors aren't drilled by brembo, but by someone else who may not have any clue what they are doing.
Old Jun 12, 2004 | 07:23 PM
Irish's Avatar
This is a democracy
dont get drilled or slotted unless you get free brake pads, the holes or slots act as razor blades on the pads, u will replace them about every 6 months
Old Jun 12, 2004 | 07:57 PM
Bill Brasky's Avatar
Seperated at Birth?
ditto to automar...
I've got Brembo blanks with PBR Ceramic pads. very worthy combo there. Well, unless you don't mind a little more dust..... they stop on a dime tho!
Old Jun 13, 2004 | 04:48 AM
mod or sell?
I was under the impression Ceramics are less dusty
at least they aren't squeaking yet
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
dcam0326
Sep 18, 2015 04:52 PM
A32goldylocks
Sep 2, 2015 06:39 AM
