working with 5 cylinders
Old Mar 29, 2001 | 10:41 AM
avargas
Hi, what it means if my mechanic says my car is working with 5 cylinders only?
Can VTC problem is causing this?
Old Mar 29, 2001 | 12:06 PM
dmontzsta's Avatar
Ford Only.
I dont think VTC would make you run on 5 cylinders.You might want to check the plugs and plug wires.You should of asked your mechanic why?
singhg83
basically, that means your screwed. You need to get a new cylinder put in which would cost u around the 1000's to get one & get 1 put in. Its happend to me before, except 2 werent workng in mine. U could drive still with 5 cylinders but you would have less power, ALOT less power. SO my advice is to get it fixed if you got the fonds
Old Mar 29, 2001 | 12:34 PM
HoJo's Avatar
How exactly do you put a new cylinder in an engine?
Old Mar 29, 2001 | 12:36 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Yeah how do you do that?? nm
Old Mar 29, 2001 | 12:48 PM
93 SE's Avatar
its not something you wanna do yourself...ive taken apart and rebuilt an engine in auto class in high school
Old Mar 29, 2001 | 01:06 PM
HoJo's Avatar
I understand that, but I was wanting toknow how you replace something that is part of the block? You can replace pistons, mabye a cylinder sleve, but not a cylinder.
Old Mar 29, 2001 | 01:13 PM
93 SE's Avatar
oh i got ya ....i dont think you can ,i think arvargas has been told hes running on 5 cylinders but he needs a piston probably
Old Mar 29, 2001 | 01:14 PM
Maximamike's Avatar
Cut the old one off and weld a new one in. Duh..
Old Mar 29, 2001 | 01:36 PM
HoJo's Avatar
Jackass
Old Mar 29, 2001 | 01:47 PM
Jeff92se's Avatar
I'm needing a caw
Oh my god, the information inside this thread is hurting my eyes!! Put in a new cylinder?? I hope someone was just being a smart-*** here.
Okay from your information, "running on 5 cylinders" means it's only firing on 5 out of 6 cylinders.
Okay since you mention VTCs, you have a 92-94SE correct? If yes, it could be a few things.
1) The coil for that cylinder could be bad.
2) The coil connection for that cylinder could be bad.
3) The spark plug for that cylinder could be bad.
Alternative reasons for running on 5 cylinders. You could have a broken piston ring and the above 3 items are working but no compression or power is being made. Only solution is to replace the piston ring. NOT THE DAMNED CYLINDER!
If you have the vg30 engine sohc:
1) Bad spark plug wire for that cylinder
2) See #3 above.
3) Bad dist cap.
4) Or again, a bad piston ring.
Old Mar 29, 2001 | 02:01 PM
Maximamike's Avatar
Jackass
Hi, I'm Johnny Knoxville, and this is cylinder replaaaaaaaaaaaaaaaaacin!
Old Mar 29, 2001 | 02:10 PM
93 SE's Avatar
we would all be lost without our professionals
Old Mar 29, 2001 | 02:41 PM
fornimage's Avatar
5 cylinder....
hahahahah...I know what u mean. I'm running on 5 cyclinders rt now too, but i know I have a bad fuel injector on cyclinder #4. If I were u I would do a compression test on each cyclinder before u go ripp'n apart ur engine. I know my cyclinders should be up around 190 psi but not sure on the VG30DE's.
Also check for spark at the wire. I checked all of those and it definitely turns out that the fuel injector is dead. Good luck!
Old Mar 29, 2001 | 03:16 PM
singhg83
Sorry for the miss information, The piston, the rod bearing, or the camshaft in the cylinder are most probably broken in the cylinder. What i meant as replaceing it was by opening up the engine, opening the valve, and replacing the piston and/or the bearing rod. Atleast this is what had happened in my max. And what i meant by getting the engine fix was, taking it to a auto body shop & getting it fixed or to the nissan dealership, sorry for the miss information
Old Mar 29, 2001 | 03:24 PM
Maximamike's Avatar
The camshaft isn't in the cylinder, and if you can pull a piston and rod through a valve opening I would.. well.. be very shocked.. BTW, why would an auto body shop fix your engine? Key words in auto body shop are "auto body"..
Old Mar 29, 2001 | 09:51 PM
fornimage's Avatar
I think his car is still drivable though so there's no way his piston is that far gone.
Old Mar 30, 2001 | 09:41 AM
Fossil Jim
My 92SE was running on 5 cylinders a couple of weeks ago (lugging from a stop and shuddering as you accelerate and really bad gas mileage). Had it checked at dealer and they said it was a bad fuel injector... cost $512 installed (ahhh!) Anyway, had it done and the problem disappeared.
Jim
jerrod99_se-l
Aug 27, 2015 08:27 PM
FlaMark
Aug 21, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
vanebecker
Aug 17, 2015 08:24 PM
kenc15
Aug 5, 2015 08:29 AM
