VE headers
Old Jun 14, 2004 | 10:01 AM
longpole938's Avatar
VE headers
anyone know if its worth it getting new headers for the VE30DE.... and if it is any good place to get some. i cant find any for the twin cam
Old Jun 14, 2004 | 10:08 AM
Jeff92se's Avatar
I'm needing a caw
Custom. They might be worth it if you build them right. Might want to do some brushing up on your fluid dynamics theory
Old Jun 14, 2004 | 06:27 PM
Aaron92SE's Avatar
NWP Engineering.com
I agree. Nobody that we know of has really done a set of headers for the VE. They might help. But if designed wrong, they might hurt! But it will be a custom job.
Old Jun 14, 2004 | 08:47 PM
MrGone's Avatar
I have VE headers, and so does everyone else
Old Jun 14, 2004 | 10:23 PM
mtcookson's Avatar
yeah, the stock ve manifolds are tubular stock, right? i would think those would flow pretty well as is. nissan tends to do a very good job with their stock exhaust manifolds. probably the best example is the old Z31 turbo's. the stock manifolds have been proven to flow enough for 400+ rwhp. that's an old engine too. the ve should easily have the same or better design. most likely there isn't much to gain.
Old Jun 15, 2004 | 02:23 PM
well since it looks like i wont be getting new headers... how do you replace a cracked stud... my #6 has a leak and sounds like ****. i just want to eventually get to it and thats what i belive is the problem
Old Jun 15, 2004 | 05:24 PM
Kikcaffine's Avatar
wont headers for the 300zx work, b/c isnt it the same engine, so wouldnt you just need to do a bit of custom fabrication?
Old Jun 15, 2004 | 09:13 PM
mtcookson's Avatar
89-91 have the same engine but the 92-94 se's have a dohc ve30de engine.
for the stud, it would need to be drilled out and replaced. they tend to be expensive to do though.
Old Jun 16, 2004 | 05:38 AM
Mizeree_X's Avatar
Getting back to his roots
http://www.4dsc.com/articles/drivetr...ld_studs.shtml
The manifold gasket part number they give is NOT the one for your engine.
KabirUTA13
19
Oct 17, 2015 02:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
ac max 92
Sep 17, 2015 07:35 AM
Maxboy23
Sep 4, 2015 06:04 PM
