The plot thickens.....hmmmm
Old Jun 18, 2004 | 10:56 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Originally Posted by 98fiveSpeed
I have a couple of bins from 3rd gen maximas but since they had a different engine...not much use.
not just the VGT bins anymore...but actual n/a VG30E bins running off the Z32 adr file...hmmmmmmm
http://forums.maxima.org/showthread.php?t=318684
also is there anyone on here who can take pictures of inside of a stock ECU and a JWT...VG 5spd or auto(2 5spds perferred)
Old Jun 18, 2004 | 11:39 AM
MrGone's Avatar
you forgot the VE
I can take pictures of the inside of a VE ecu lol.
whats adr mean again?
and how would VG guys go about writing these?
It's been a while since v.1addaeschooledmeoneeprom(IIRC)stuff
I know mtcookson was sending his to some guy in canuckistan. hmmm.
Old Jun 18, 2004 | 02:16 PM
Maxpwer's Avatar
No turbo, no care!
I just ordered my JWT, but I will take pictures of the inside in "4-7 weeks". I can post a stock ECU 5-speed now if that helps any??
Old Jun 18, 2004 | 04:03 PM
DA-MAX's Avatar
please do
shawn...adr is address file...I'm pretty sure its the same as the "stable" files used on my Honda editor. basically from my understanding its a base code to set everything up on....and then you put the bin file "onto" it and it all magically comes together in the editor as a whole.
@ canuckistan
if I get some time tonight I'll open these up in the Hex Editor and also se if I can open them in that Nissan Rom Editor thats floating around
Old Jun 18, 2004 | 08:44 PM
HTPerformance's Avatar
Originally Posted by DA-MAX
please do
@ canuckistan
http://cherrypicker.tripod.com/turbo...dett/id10.html
This is the link to a great deal of info, if MrGone ever decides to send one or both of his ECUs, he will be the proud owner of a retuned ecu.
Brian
Old Jun 18, 2004 | 09:07 PM
MrGone's Avatar
j00 cover shipping
Old Jun 18, 2004 | 10:15 PM
mtcookson's Avatar
VG 5-speed:
has a different eprom due to trying to tune it
Old Jun 21, 2004 | 11:01 PM
Maxpwer's Avatar
No turbo, no care!
Here is an 89 5-speed CA spec. This is right before I sent it to JWT. I will post picks of the "after" as soon as I get it back
Old Jun 21, 2004 | 11:16 PM
maximagxe90's Avatar
Hi,
how can you tell if it is a CA spec?
Old Jun 21, 2004 | 11:23 PM
Maxpwer's Avatar
No turbo, no care!
Originally Posted by maximagxe90
Hi,
because I took it out of my CA spec car.
Edit: If you werent sure if it was CA spec or not, the ECU model number can be matched up on the JWT website to find out the year, trans, and fed/ca spec.
Old Jun 21, 2004 | 11:43 PM
Hi,
is there any difference between the fed and ca ecu?
Old Jun 22, 2004 | 03:58 AM
DA-MAX's Avatar
cool...looks like the guy used 27C256 UV chips, and it looks like he soldered it in permanently to the board with no socket
maybe I'll go get a spare ECU this weekend and **** around with it
Originally Posted by mtcookson
VG 5-speed:
Old Jun 22, 2004 | 08:21 AM
Maxpwer's Avatar
No turbo, no care!
Hi,
Yes, the CA cars have some extra functions like Exhaust Gas Temperature, altimeter (for air density adjustments) and a few other things I cant think of right now.
Old Jun 22, 2004 | 08:49 AM
Hi,
if the car was design for ca wouldn't it say CA under the hood?
Old Jun 22, 2004 | 08:55 AM
Maxpwer's Avatar
No turbo, no care!
Hi,
Neither of mine do, so I would say no
Old Jun 22, 2004 | 09:18 AM
Hi,
when i look under my dad car hood i can see CA in one of the stickers,
could it be that the 95 and later models had the name of the state in one of the stickers under the hood,
Old Jun 22, 2004 | 01:43 PM
mtcookson's Avatar
Actually, it does have a socket in there. I ordered a couple chips and a socket and sent everything to him at once. He had someone take out the old chip and solder in the socket. From there all I had to do is send back the chip itself so he could reprogram it once we figured out what it did. I can't remember which chips I ordered but once get on my computer I'll find out and let you know. You're probably right about the part number though.
dawalkster
Mar 26, 2004 05:03 AM
ABS
Jan 24, 2004 11:47 PM
MacGyver265
Dyno Discussion and Slips
Sep 21, 2003 04:27 PM
meximax
Jan 31, 2003 11:08 AM
