Abs Unit
Old Jun 20, 2004 | 09:47 AM
bigkgs's Avatar
Abs Unit
My '92 SE...has a leaking ABS UNIT....I need to replace it with a stock replacement, but i wasn't sure if it has to be from another 1992 SE...or is it interchangeable between year or model?
Old Jun 20, 2004 | 10:57 AM
nismobaron's Avatar
They're interchangeable - check the model number to be 100% sure. Probably find the same unit used on Stanza, 300ZX & other Nissans of that era. I've even seen the same units on some Subaru's of a similar vintage.
Old Jun 21, 2004 | 12:14 PM
bigkgs's Avatar
Interchangeable between which years....91? 93? 90?.....
What should I look for when comparing model #'s? Should they begin with the same set of #'s or something?.....
Old Jun 21, 2004 | 12:21 PM
Jeff92se's Avatar
I'm needing a caw
Unless you know for sure, I'd only look for abs units from SE maximas from the year 1992-1994 (including those years) ie.. VG powered maximas had different abs systems than VE powered maximas.
Old Jun 21, 2004 | 12:56 PM
bigkgs's Avatar
Would I just need the unit or would I need to get the entire computer with it....and also would I need an electrician to replace it.
THanks
Old Jun 21, 2004 | 01:01 PM
Jeff92se's Avatar
I'm needing a caw
IMHO, you don't need an electrican nor do you have to replace the abs ecu (if it's not bad)
If you are certain it's the abs unit that's bad, replacement is pretty easy. I'd refer to a service manual but it's basicly unhook the battery for safety. Unplug the abs connectors. GENTLY unscrew the abs lines into the unit and use a rag to catch any leaky fluid. Then undo the abs mounting bolts and remove unit. Install is the reverse of removal. Then carefully rebleed the brake lines. I don't remember if you have to rebleed the lines with the battery undone or not but that would be safer
Old Jun 21, 2004 | 01:07 PM
nismobaron's Avatar
Maybe sensor & software upgrade between early & later models - but the abs actuator is the same.
The unit code on my max is: 47600 96E00 It's a '93 NZ VG - I've seen JDM VE of similar year with same actuator.
Better to get actuator from 92-94 years, though. Won't matter if it's SE or GXE trim - same unit used.
Old Jun 21, 2004 | 01:10 PM
Jeff92se's Avatar
I'm needing a caw
Cool!..................Good info to know
Old Jun 23, 2004 | 10:12 AM
bigkgs's Avatar
Anyone kno some1 with a good ABS unit for a good price.......What's the price range of these things....
Does any1 with a 92 - 94 SE know if this ABS model number would go well with our edition.......I'm not too sure how to tell.....Let me know,
47600 86E00
THANKS
Kingsley
Old Jun 24, 2004 | 01:45 AM
nismobaron's Avatar
47600 86E00
THANKS
Kingsley
I think the first set of numbers is the part code & the second set the update model code - this is a similar pattern on most nissan parts. If it's from a 3rd gen max, it's the right part as it matches my code.
Old Jun 24, 2004 | 07:41 AM
bigkgs's Avatar
I looked up the part #, and it came up as an ABS modulator. Is that what I'm looking for, because I'm hearing all these different types of names for it.....
The part that I need is located above the passenger side under the hood, next to the radiator.
I'M SO LOST......
Thanks for every1's help
Old Jun 24, 2004 | 08:01 AM
Jay93SE's Avatar
Yes. Pump, unit, modulator. It all refers to that thing that looks like a baby Briggs and Stratton by your rad.
Old Jun 27, 2004 | 12:34 PM
bigkgs's Avatar
Would I need to get anything else along with the actuator/pump (i.e. wires, cords, hoses, relays, sensors).....or is the unit enough. Because I just want to make sure before I buy the unit.
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
