Not your average window question!
Old Jun 21, 2004 | 10:20 AM
VASHtheSTAMPEDE's Avatar
alright, i found out that my window regulator has completely failed on the driver's door, (~insert sarcastic tone~)What! window trouble on a 3rd gen maxima, that's odd.
But, back to my question, The window is rolled completley down and i was told that you would have to pull it up manually to reach the regulator, is this true and if it is how could i do this with out damaging anything else inside my door.
Holla back!
Old Jun 21, 2004 | 10:27 AM
DanNY's Avatar
Ad·min·is·tra·tor
if your regulator did break..you can just reach in and lift/push the glass up since it won't be under tension of the regulator.
Old Jun 21, 2004 | 11:41 AM
BOB-O's Avatar
Even if it is still connected and binding, once you get the panel off the door you can see what the problem is and disconnect the regulator.
Old Jun 21, 2004 | 04:09 PM
Magnifico's Avatar
it'll all become clear once you get the door panel off, and use craigs fAQ. if you need to get it up right now and you cant do it from above just take the door panel off and push it up from the bottom. it wont damage anything
Old Jun 23, 2004 | 09:00 PM
dewmax007's Avatar
ya, and a piece of lath, or 2x2 can be custom cut to hold it up to keep the thieves out...just why do i know this???
Old Jun 25, 2004 | 12:11 PM
maxZ93's Avatar
this happened to my 1993 max se, to the rear driver side door. unscrew the regulator and unscrew the screws attaching the regulator to the window slidy thing. lol slidy thing, anyways. i used a piece of wood to hold up my window temporarily, but then i installed my new regulator, it was a b i t c h. and it works awesome now
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
