stiff steering wheel
what causes your steering wheel to be stiff when turning (not smooth).I drove my friends 1992 GXE and I could turn his wheel with one finger no strains, mine on the other hand takes a bit more effort. there is new fluid, belts, no leaks.
any takers?
any takers?
Originally Posted by Jeff92se
Wider wheels/tires for one
why would I have to get wider wheels/tires if he is running on OEM specs?
i think he meant wider wheels would make it harder to turn.
between the gxe and the se i think the gxe's steering is a bit easier to steer compared to the se most likely because the se is meant to be sportier. i could be wrong though.
[/COLOR][COLOR=Black]
[COLOR=Black]
I want mine stiffer. oh well
The SE's steering is quite a bit stiffer than the GXE system from the factory.. not sure whether it's in the pump, rack, or what, but it's much lighter in the GXE.
I'd rather have the stiffness of the SE.. Right now if I hit bumps while I'm holding the wheel with one hand, my arm moves enough to turn me into the next lane... not cool in heavy traffic. I'd hate to see it any softer than it is now.
Yeah, when I upgrade from stock worn 140K mile suspension to new Konis and Eibachs.. I noticed that when I hit a bump, it was much harsher. I have to hold tighter on the steering wheel to keep from going in the other lane. I love it b/c the tires are in perfect contact with the road at all times. So the driver better be alert.
Originally Posted by Matt93SE
that's more bumpsteer and the wheel twitching than increased traction.
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Originally Posted by Aaron92SE
But I'm sure I have more traction when compared to my 140K mile stock suspension! Even with the bumpsteer! ![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
when you talk about suspension, bump-steer is a very common word and something most people have problems with.. but in the case of the general public, they just think the car is twitchy when you hit bumps because of the suspension... it is, but it's because the alignment/steering is changing as the springs compress and the ride height changes. that's bump-steer.
matt ,
is your GXE steering response stock? or did you do some mods to acheive this ??
the steering response is one of the only things i hate about my maxima when trying to increase performance. It feels like im driving a bus when i take a turn...
later
later
JoshG
51
09-21-2015 10:41 PM
