Manual tranny noise?
Old Jun 22, 2004 | 05:37 PM
ghostmax's Avatar
92 se 5spd.
Low grinding noise from front driver's side, increases with acceleration in all gears. Goes away when I take my foot off the pedal or push the clutch in. I was wondering if it may be a bearing or something in the tranny. I had a wrong NAPA driver's axle in for about 6 months; then I put in one for an automatic tranny and it fit perfectly.
Any thoughts are very appreciated. Thanks!
Old Jun 22, 2004 | 06:22 PM
subs1000w's Avatar
does it do this when you are not moving in nuetral with the clutch out
Old Jun 22, 2004 | 06:31 PM
ghostmax's Avatar
no, only when i accelerate in any gear. what does a slipping clutch feel like?
Old Jun 22, 2004 | 06:50 PM
subs1000w's Avatar
if your clutch was slipping your car would rev up in gear without accelerating
could be differential bearings
Old Jun 22, 2004 | 08:41 PM
ghostmax's Avatar
i just read motorvate.ca and i'm thinking it might be my differential carrier bearing which might have been damaged when i had the wrong axle from NAPA installed causing too much pre-load on it. my axle seal seems to be leaking despite installing a new one recently. i was very careful not to tear it.
the clunk-clunk grinding sound increases in speed when i accelerate and is noticeable in all gears, especially in 1st and 2nd.
any other thoughts?
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
