Driver door hinges
Old Jul 1, 2004 | 10:31 AM
goon9's Avatar
Driver door hinges
Where can I get new ones? Is it best to change them without the fender on?
Old Jul 1, 2004 | 03:21 PM
HTPerformance's Avatar
I have a pair available for the drivers side. They were from the rear door, but they should work on the front too.
If you want them let me know, they are light blue, but you can spray paint them black to match your car if you like.
$30 shipped.
Old Jul 3, 2004 | 06:13 AM
pkfinn's Avatar
I bought brand new ones from the dealer last year. They were only about $20 - $25 each from what I can remember. You can change them without removing the fender by unbolting the door from the hinge, support the door with a floor jack or something, then swap the hinge out on the body and reattach the door. It may take a little tweaking to get it lined up right, but it's not too bad. One of the washers on each hinge was tack welded to the hinge, I guess that locks the position once the door was aligned at the factory. You can grind off the weld to remove and reuse the washer. I didn't weld it back on, and it's been on there for a year or so and hasn't moved.
Old Jul 3, 2004 | 07:01 AM
Matt93SE's Avatar
STFU n00b!
If you're good at lining up body panels, then I'd say to take the fender off.. makes it much easier to get the door lined up properly, then you have to get the fender back on and lined up..
If you don't, it's a PITA to line up the door, but you don't have to worry about the fender. I recommend just puling the fender though.. less hassle, IMO.
and buy them from the dealer. no offense to the other guys, but don't buy used hinges. They're only about $12 each from the dealer for the fronts, and $20 for the rear doors.
Old Jul 3, 2004 | 07:29 PM
goon9's Avatar
bang the 30 dolla deal.
Thanks matt.
jsmith24
Feb 1, 2016 12:35 AM
ef9
Sep 29, 2015 11:29 PM
JoshG
51
Sep 21, 2015 10:41 PM
95naSTA
Sep 21, 2015 06:50 PM
ajahearn
Sep 19, 2015 03:03 PM
