Help a new 89 maxima owner
Old Jul 8, 2004 | 05:29 PM
JMAGIC89's Avatar
i just bought a 1989 black maxima and there a couple problems with it im 18 and this is my first car so i dont know much about them but yea here are the problems the fuel gauge and the hot/cold gauge doenst work so i dunno how much gas i got and there is a transmission fluid leak thru the gasket i belive and whenever i turn the car left i hear a scarping sound someone told me it sumn with the wheels and my horn is disconnected
any help would be appriciated lany help thx
Old Jul 8, 2004 | 05:32 PM
DMad8724's Avatar
Well, a new cluster might fix the gauge problems...the leak in the gasket is some sort of TSB if I remember right...it looks like a head gasket is blown but it's not, I read that some where...do you have aftermarket wheels/tires on it? they could be the wrong size causing rubbing...and the horn could be wiring somewhere...check for a short
Old Jul 9, 2004 | 07:03 AM
JMAGIC89's Avatar
what is a cluster and how much does that cost? what is a tsb? yea i got some aftermarket wheels on it but i took it off and put the stock rim back on it
Old Jul 9, 2004 | 07:52 AM
DMad8724's Avatar
a cluster is the gauges...you can get one at a junkyard...mine i think was like $15...tsb = technical service bulletin, like a recall but different...the aftermarket rims were probably your rubbing problem...welcome to the org and if you can get a cardomain
Old Jul 9, 2004 | 07:48 PM
CamryKilla's Avatar
well you can replace that cluster with one from the junkyard. There is a TSB website if ou check the FAQs at the top of the 3rd gen forum. Welcome aboard and get some pics up on cardomain.
Old Jul 10, 2004 | 08:10 AM
JMAGIC89's Avatar
i found out what the scraping was i have a bent control arm does anyone have a estimate on how much it would cost to fix it?
Old Jul 10, 2004 | 09:57 AM
Mizeree_X's Avatar
Getting back to his roots
You can get a new control arm from www.internetautomart.com (org member) for $85 + shipping. Since it sounds like you haven't had alot of experience working on cars, you should probably have a mechanic install it. It would about 1-1.5 hours labor I would imagine.
Old Jul 10, 2004 | 10:15 AM
JMAGIC89's Avatar
yea this is my first car i bought it for 700 i just need to get those things fixed and it will be running well i guess and i have another concern when i turn the car on and the engine is running i feel a mild shake i wonder what that is.could it be a loose engine mount?
CRizz
41
Jun 7, 2021 05:42 AM
MplsMadMan
Sep 4, 2015 02:23 PM
Team STILLEN
Aug 10, 2015 04:29 PM
