What is the normal idle speed in "D"?
Old Jul 9, 2004 | 06:40 AM
m_maxxy's Avatar
Whats up ppl,
My idle speed in "D" or "R" modes (with depressed brake pedal) is about 600-650 RPM. When I shift to "N" or "P" it raises to 700-750. I know that 750 +/-50 is a normal idle speed in neutral. But I can't find any reference in FSM as to the "idle" speed in drive mode.
So can somebody tell me what is the normal idle speed for the drive mode?
And another question. My idle is slightly unstable (needle jumps up and down about 50 rpms). I thought that I have a vacuum leak and was going to get to the lower manifold to check hoses there becuase I've already checked all the reachable hoses and found nothing. But according to FSM if there is a vacuum leak in the system rpms should go up when pinch blow-by hose (the one that goes to PCV). But in my case it didn't happen at all.
So the question is what else should I check?
Thanks in advance.
Old Jul 9, 2004 | 06:52 AM
internetautomar's Avatar
mod or sell?
I idle about 500 -550 in Drive
But then again I have a VE
Old Jul 9, 2004 | 10:07 AM
Aaron92SE's Avatar
NWP Engineering.com
500 is way low. That is on the verge of stalling. So I bet your idle in D is vibrating like crazy.
My idle in N is 750 and my idle in D with the brake firmly pressed is about 650 rpm. I'd say, if your idle is any lower than 600 in D, then you are experiencing some heavy vibrations b/c of a low, rough idle. I don't know what would cause a low idle like that, but for you, don't worry about that. 650 rpm is fine for being in D.
That blow by hose, not many people have ever replaced that before. So yours is probably the original hose, which means it's dry rotted and rock hard. So if you squeeze it with pliers, it might shatter. Mine did after I replaced it. But with a new hose in place, you can squeeze it. I'm not sure if my idle changes when i squeeze it, I haven't tried it.
I'm glad you have a FSM. You know more than 95% of the people on this forum just b/c you have a FSM. Just follow those steps in the FSM for a rough or unstable idle and see where that gets you.
Old Jul 9, 2004 | 10:41 AM
mod or sell?
it idles fine. cosidering it's got a straight pipe on it
Old Jul 9, 2004 | 12:04 PM
Aaron92SE's Avatar
NWP Engineering.com
That's wierd. My idle has dipped to 500 before and it stalled once. And if it didn't stall, the car shook like crazy and barely caught back up. 500 is low. I only had idle issues b/c of the ECU tinkering I was doing.
Are you sure it isn't 600? Well, I'm only talking about how it is for my VE. That's all. I have a testpipe too. But I don't know what that has to do with the idle.
Old Jul 9, 2004 | 12:45 PM
mod or sell?
who said test pipe? I have no muffler or resonator just straight pipe 2.5" crushbent
hilly billy exhaust
Old Jul 9, 2004 | 02:12 PM
Aaron92SE's Avatar
NWP Engineering.com
hilly billy exhaust
Haha, dang. That has to be LOUD. "What!?"
Old Jul 9, 2004 | 02:41 PM
m_maxxy's Avatar
You're right man it's rock hard. And yes I squeezed it with pliers but nothing changed. Apparently it's time to replace the hose.
I'm really glad that I got FSM. Even if I won't use all the informaton in it it's already repaid itself.
Yes I'm trying to follow the steps in FSM to fix the problem. But you know it's in the man's nature always to look for the shortcut
Old Jul 9, 2004 | 04:42 PM
AscendantMax's Avatar
You should be ok, my idle is around 650-700 when the tranny is in D.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
