a/t harsh shifting
Old Jul 22, 2004 | 03:50 PM
n1_saxman's Avatar
a/t harsh shifting
my tranny is shifting pretty hard. It seems to be shifting at full line pressure no matter what RPM the engine is at or how I drive it, slow or fast. What's the deal? I know there is a sensor somewhere. What is that thing called?
~Ryan
Old Jul 22, 2004 | 04:37 PM
Maxzilla91's Avatar
.. i think u need new transmission fluid..
Old Jul 22, 2004 | 06:09 PM
internetautomar's Avatar
mod or sell?
the drop resistor may be bad
Old Jul 22, 2004 | 06:11 PM
Scope's Avatar
Im izz sexay
Or it could be that you need a new resistor. Look in your engine bay near the intake there should be two wires connected by a clear glass like thingy. Replace that. If you need fluid then the tranny will take forever to do anything at full pressure. I speak from experience and a bad tranny.
Old Jul 22, 2004 | 07:20 PM
Evil_Twin's Avatar
hey guys... what is a drop resistor
Old Jul 23, 2004 | 04:21 AM
mod or sell?
a resistor that "controls" the transmission line pressure, and shifting firmness
Old Jul 23, 2004 | 12:06 PM
floods943's Avatar
My transmission seems to shift "harder" at below 2500rpm; and nice and smooth above that mark...and after about 5-10 minutes of driving, the hard shifting stops.
I always figured this is just due to the fact that the tranny has approx. 140,000 miles on it. The Fluid still has it's color and everything; though if it gets worse I'm going to start paying closer attention.
Is this anything to worry over?
Old Jul 23, 2004 | 07:38 PM
n1_saxman's Avatar
is this the drop resistor?
Old Jul 24, 2004 | 03:15 PM
n1_saxman's Avatar
some help?
Old Jul 24, 2004 | 04:39 PM
Scope's Avatar
Im izz sexay
I think that is. Now all you have to do is find the other wire to re-insert it.
Old Jul 24, 2004 | 04:42 PM
Scope's Avatar
Im izz sexay
floods943 when you check your fluid do you do it in gear at operating temp? To do this put the car in D and pull the e-brake. Then clean the dipstick and check it from there. Seems like a fluid issue. When was the last time you had the fluids completely flushed?
Old Jul 24, 2004 | 06:59 PM
Jack.'s Avatar
Wow i have an issue with soft shifting... It revs high first and then pretty much skips second like it didnt exist. i hate auto's
Old Jul 25, 2004 | 12:49 AM
pinkfloyd's Avatar
I know i have read a good right up on how to change atf. something about finding the lead line to the cooler and letting 2 quarts out and then putting two in....ect ect. do about 10qts and its flushed. jiffy lube wanted like 200$ for it. If anyone knows where that write up is post it for these guys.
I feel kinda stupid now but here is the link. its for the 4th or 5th gen maxima, but its not a bad read. http://forums.maxima.org/showthread.php?t=149056
Old Jul 25, 2004 | 07:10 PM
Evil_Twin's Avatar
if you put too much transmission fluid in the tranny, will it cause harsh shifting?
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
