ECU Upgrade and advance timing upgrade question
Old Jul 26, 2004 | 12:55 PM
KRMaxima21's Avatar
I'll be getting a JWT ECU in the upcoming weeks (thanx chris91se) and I know about what it does. Now I was about to have my timing advance 2-3 degrees on Wednesday but what I want to know is will I run into problems if I leave it at 17-18 degrees and then the ECU upgrade advances the timing also??
Old Jul 26, 2004 | 01:12 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
put it back to stock base timing...the JWT unit is set to work off 15 BTDC.
Old Jul 26, 2004 | 01:34 PM
-shock211-'s Avatar
a tad OT but...
can't we only adjust our timing by 5deg. increments?
Old Jul 26, 2004 | 01:38 PM
Jeff92se's Avatar
I'm needing a caw
Pulley is marked in 5 deg increments but doesn't mean you can't adjust inbetween those marks.
Silly Canadians again.
Originally Posted by -shock211-
a tad OT but...
MrGone's Avatar
a tad OT but...
nope, you can adjust it in 1* increments or even smaller if your just that good
Addae, what if you put it at 20*
Old Jul 26, 2004 | 04:58 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
put your timing back to stock when running a JWT ECU. also when you finally get it make sure you run premium fuel...
Old Jul 27, 2004 | 05:42 AM
DA-MAX's Avatar
this is kinda hard for me to explain, but ah well...I'll take a shot...this is my take on it. if its at 20 then that would throw it off...all of their ajustments are made from base 15*(stock timing maps)...so say you put it at 20* combined with the JWT advanced adjustments early and midway thorugh the RPM band, the result would be the values being waaaaaaaaaay too high and possibly dangerous. if you look at most stock timing maps you can see that they are REALLY hot(sometimes up to ~40*) in the low end and cool off as you progress into the top. so say you start with 20*, then apply the JWT advanced values....timing at low end will shoot through the roof and theres a good chance you'll detonate out the butthole. I'll put up the timing maps I run later and you can see what I mean
Old Jul 27, 2004 | 07:33 PM
DA-MAX's Avatar
this is my curent n/a program fo the teg...Dinian fuel/ign values, 7300 rev limit, with my own little tuning twist. vacuum across the top, rpm down the left...thats based off stock honda timing. so imagine haveing the Maxima timing at 20(rather than 15) and then applying a major timing advance especially in the lower RPM columns....unless I'm way off in my thinking I see trouble. I wish this program had map trace, then you could see the actual progression of timing along the map with the car accelerating through the powerband
Balkins
Feb 1, 2016 12:45 AM
incubusjohnny
Nov 3, 2015 05:18 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
1992maximase30
Aug 5, 2015 09:27 PM
