engine ticking
Old Jul 28, 2004 | 08:12 PM
jaemax's Avatar
engine ticking
does anyone know what this ticking noise can be and can it be fixed without much cost?? I am interested in doing this job myself. I think it is the rocker arm or valve?
jaemax
Old Jul 28, 2004 | 08:31 PM
CamryKilla's Avatar
faqs........
Old Jul 28, 2004 | 08:33 PM
thumpyls's Avatar
if u have a ve motor then it might be your vtc...$$$$
Old Jul 28, 2004 | 10:02 PM
Cliff Clavin's Avatar
Way out West
it says he has a 91 (VG engine) so I would guess exhaust manifold studs.
Old Jul 29, 2004 | 07:02 AM
jaemax's Avatar
engine ticing
I am certain that it is not the exhaust manifold studs as this sound is way different than that... I have a minor oil leak from the main pulley and when I have the right amount of oil it does not sound but when I start to get to what I would say somewhat of a low level the valve or rocker arm ticks at the 2-6 cylinders.... I know which one it is cause when I changed the injectors, i pulled apart the valve cover to replace the gasket and i played with the arms and one (which I think is the one that makes noise) has some play... I dont know from there what it is...
I think i will just fix the main pulley gasket...
JAe
Old Jul 30, 2004 | 04:46 PM
StRacer718's Avatar
I had a oil leak and I had a ticking sound from the heads. Usually when you have an oil leak and the oil level gets low you get that ticking sound.
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
ColdCananda
Sep 20, 2015 10:45 PM
seesole
Sep 14, 2015 12:38 PM
