Will this battery fit?? ~ Optima D31A
Old Jul 31, 2004 | 04:22 PM
molehill84's Avatar
Hey Guys,
I have a pretty big stereo system with a lot of accessories and my cousin just put the air ride suspension on my car so I think it's time to upgrade my battery again... Since they don't make a bigger alternator for our cars I think I'm going to go for an Optima Yellow top which should do the trick...
Check out this battery in the link and please let me know if this battery will fit where our stock battery is housed... Thanks ~ Joel
http://www.remybattery.com/350/shopexd.asp?id=5436&catid=171&cat=Yellow+Top%3Cbr% 3EDeep+Cycle+Batteries&subcat=168
Spec`s on the battery:
SIZE
Length: 12 and 13/16"
Width: 6 and 1/2"
Height: 9 and 3/8"
Optima Part Number : D31A
BCI Group Size : 31 (SAE Post Terminal)
Voltage : 12
Cold Cranking Amps @ 0° F : 900
Cranking Amps @ 32° F : 1125
Reserve Capacity Minutes : 170
Amp Hour (20 Hour Rate) : 80
Weight: 69 lbs.
Old Jul 31, 2004 | 06:25 PM
DanNY's Avatar
Ad·min·is·tra·tor
either use 34 or 34R size.
the 34R is the "preferred size" since the battery cables don't have to go that much farther.
the 34 you need to pull the cables a little farther to get to the terminals.
i doubt the 31 would fit.
Apr 16, 2020 05:15 AM
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
Pied
Sep 26, 2015 03:29 PM
