Deactivating Stock Alarm
Old Aug 18, 2004 | 05:01 PM
pest2001's Avatar
i have a aftermarket alarm on my 92 gxe and sometimes when i unlock the car with my remote the stock alarm goes off and its really annoying can someone tell me how to deactivate the stock alarm so it wont go off any more when i open my doors
Will
Old Aug 18, 2004 | 05:13 PM
«§»Craig B«§»'s Avatar
unplug the stock alarm (under the steering column, to the left)
Old Aug 18, 2004 | 06:17 PM
goon9's Avatar
What craig said. It's just a little silver box with a plug on the underside.
Old Aug 18, 2004 | 08:18 PM
5 ltr. beater's Avatar
do i have to take apart the steering colum to get to it?
Old Aug 18, 2004 | 08:56 PM
no, it's just to the left of it, not on it
Old Aug 18, 2004 | 09:33 PM
GRNMAXDMON's Avatar
it should be right in front of the TCU it says anti-theft deterrant system or something like that. just unplug it thats it.
Will y didn't u have the alarm hooked up with ur stock alarm???
Old Aug 19, 2004 | 08:45 AM
Knight4's Avatar
Do you carry your key on your remote entry fob?
When the stock alarm is going off, a) stick the key in the driver's door lock, b) lock the door manually, c) unlock the door...
Very simple and doesn't involve having to unplug the stock system.
Mine does this every once in a while also. Don't quite understand why, but the solution seemed easy enough.
Old Aug 19, 2004 | 10:20 AM
-shock211-'s Avatar
TCU - traction control unit??? WTF
if that's the case i need one of those
Old Aug 19, 2004 | 10:27 AM
R92max's Avatar
Best thing to do is take it back and have em do it right. They screwed up like that on an install on one of my Nissans, I fixed it myself so that wouldn't happen. You need to have it set up so when it arms it arms factory alarm and disarm does likewise. Believe it requires a couple diodes. What's happening is you are locking the door with it open, and that sets the factory alarm.
Old Aug 19, 2004 | 10:38 AM
TCU = time control unit (controls dimmer, wipers, dome light fadeout, etc)
you only need one diode to interface any aftermarket alarm with the stock alarm
Old Aug 19, 2004 | 12:38 PM
-shock211-'s Avatar
oh,
of course.....i was just discussing traction control & lsd tech stuff with a buddy when i posted that....so traction control was on the brain.
:attention
Old Aug 19, 2004 | 11:31 PM
Yourself
thats funny my first maxima is a white 92 gxe auto and it came w an aftrmrkt alarm and does the same thing it took me a while to figure it out but here goes ...if i use the aftrmrkt remote only it locks+unlocks the doors w\no fac alarm arming but if i lock the doors w\the door lock button it arms fac alarm then i press arm on aftrmrkt remote ..now i got 2 active ...and when disarming if i dont first unlock w\the key it sounds the fac alarm cause it detects the locks unlocking i dont know if this is how its supposed to be but i learned to live w\it
Old Aug 20, 2004 | 05:29 AM
nubiannupe's Avatar
OG Maxima.org Member
Oy Vey, dude! Trust me when I tell ya that's NOT how it's supposed to behave - if it's hooked up correctly.
People... (and Craig can back me up on this, cuz he and I have gone over this with I-don't-know how many org-y members..) some alarm systems come with a dedicated wire to disarm/rearm factory security systems, while (again, like Craig pointed out) a simple diode-isolated wire running from the factory security disarm wire (hmmm....wonder if I should tell 'em WHICH wire to tap into, or let them do their OWN research???) to your unlock wire on the alarm system will not only disarm the aftermarket alarm, but also disarm your factory alarm as well.
Or, just do like R92max said and take it back where you got it from and MAKE them do it right!
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
