Changing struts - first time how?
Old Aug 19, 2004 | 08:44 AM
doomtoo's Avatar
I think I can figure it out between seeing one taken off once, and the haynes manual, but does anyone have any additional links/help for replacing the struts on a 91 GXE? Should just the spring compressors you "borrow" from autozone work fine?
Any help would really help
Old Aug 19, 2004 | 09:59 AM
Mizeree_X's Avatar
Getting back to his roots
there's a writeup on 4dsc.com. It'll be your new best friend. IMHO, the gland nut on the rear struts is the biggest PITA you'll encounter. I used a huge pipe wrench and a gigantic bench vice to get mine off. Other than that it was pretty straight-forward. Read the writeup multiple times and cross-reference it with the Haynes so you are familiar with what everything is. Good luck.
Old Aug 19, 2004 | 10:18 AM
-shock211-'s Avatar
get yourself a oxygen/acetylene torch or at least a propane torch to heat up the gland nut on the rears. because like mizeree said, the rears will be the biggest PITA..
and be careful not to drop your rear strut assembly at all because you will blow an abs sensor if you drop it....i know from experience...
Old Aug 19, 2004 | 11:32 AM
Mizeree_X's Avatar
I just duct taped my ABS sensor to one of my parallel links. It didn't come off the car with the strut assembly.
Old Aug 19, 2004 | 12:35 PM
-shock211-'s Avatar
when did my struts i couldn't be bothered to remove the abs sensors. but i learned that it's worth doing after having to replace both rear sensors.
Old Aug 19, 2004 | 01:16 PM
Mizeree_X's Avatar
Hehe, live and learn.
kjlouis
Nov 24, 2018 06:09 AM
MatthewsMaxima
Sep 11, 2015 03:21 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
laparka66
Aug 6, 2015 09:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
