Car won't start, please help.
Old Aug 19, 2004 | 09:04 PM
Iron_Curtain's Avatar
Ok, so I decided to test all my injectors with an ohm meter. When I opened the connections I noticed a lot of green corrosion and build up. So I sprayed the connections with electrical connection cleaner. After letting everything dry, and testing the ohm rating, I reconnected the connectors. When I tried to start my car, it would turn over but wouldn't start. I can't figure out what the problem is. I am getting spark to all my plugs, and the coils. Any ideas why the car won't start? Could spraying the connections possibly do anything? Any help is good help. Thanks.
P.S. All this work was done with the intake still intact, all I did was disconnect the connectors. Also is 13.8 ohms an indication of a bad or failing injector, or is that still good?
Old Aug 19, 2004 | 10:27 PM
BML94GXE's Avatar
Maxima Withdrawl is real
is the fuel pump fuse good, when you turn the car to the "on" position but dont start it can you hear the fuel pump start and fun for a few seconds and the stop? just a though
Old Aug 19, 2004 | 11:05 PM
smokyman13
do you smell any fuel when you are trying to crank it over?....maybe while checking the ohms you disconnected something giving fuel to the injectors, or forgot to put the fuel pump fuse back in....
Old Aug 20, 2004 | 04:35 PM
internetautomar's Avatar
mod or sell?
13.8 ohms is still within tolerances
Old Aug 20, 2004 | 04:49 PM
Kikcaffine's Avatar
Do you have any fuel in the tank? I know this is a stupid sounding comment but you would be surprised....
Old Aug 21, 2004 | 11:28 AM
Fuel pump turns on, no fuel smell, and there is fuel in the tank (almost half a tank). I checked to make sure all the connections are on the right way. I even disconnected the battery for 3 hours and reconnected it. The car still just turns over and won't start. Any other ideas, I really need to get this running and I don't wanna have to pay someone to tow it.
Old Aug 21, 2004 | 11:31 AM
smokyman13
have you checked all the fuses? I remember when my car was trying to start but wouldn't...the eng cont. fuse above the hood latch inside the car, blew for some reason....i later figured out there were a few opened electric wires on my harness...so i electric taped all the wires, put in new fuse, and boom it started and never blown fuse yet
Old Aug 21, 2004 | 11:32 AM
smokyman13
auto or 5spd btw?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
kirkhilles
Aug 8, 2015 10:53 AM
