Door Lock Timer
Old Aug 22, 2004 | 02:21 PM
kachorknik's Avatar
Door Lock Timer
I finally got the door lock timer out of the car... are all the solder joints cold solder? Or are there specific sections i should solder? Is there a FAQ that i can't find? Anyone know? Thanks!
Old Aug 22, 2004 | 04:42 PM
«§»Craig B«§»'s Avatar
the PCB is pretty small, it would only take a few minutes to do the entire board
bu generally, it's around the relay near the bottom of the board
Old Aug 22, 2004 | 05:22 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
ive got to do mine again it was fine for like 6 months after i did it. now its acting up again
Old Aug 22, 2004 | 07:43 PM
mpdugg's Avatar
Here is a tutorial. It is not perfect but it gives the general idean of the repair I did.
Cheers,
Matthew
http://65.65.104.211/cars/maxima/rep...ckTimerBox.htm
Old Aug 22, 2004 | 08:26 PM
unsprung's Avatar
Cheers,
Matthew
I need to fix mine up since it's been messing up the past month, but that link is really a time saver. If it isn't already up in the FAQ, it should be.
Old Aug 23, 2004 | 06:05 PM
YoU CaNt SeE mE
your the man
Old Sep 10, 2004 | 09:56 AM
mike92's Avatar
Link not working
Hi all, I have the same problem. The solution link you posted is not working, could you post the solution again?
Thanks.
Old Sep 10, 2004 | 11:04 AM
dewmax007's Avatar
ditto link doesn't work.
Old Sep 10, 2004 | 11:42 AM
remove door lock timer (grey box to the right of the steering column after removing lower dash)
take circuit board out
resolder
put back in
contact Matt93se if you can't solder it yourself
Old Sep 10, 2004 | 12:04 PM
mike92's Avatar
I have removed the door lock timer, I have taken the circuit board out. Now what to resolder? everything? Capacitors, resistances...???
Old Sep 10, 2004 | 12:07 PM
might as well resolder everything, but generally it's the relay joints that go bad
look at each joint with a magnifying glass for cracks in teh solder joints
should only take you 10 minutes or so to redo the whole board so why not
Old Sep 10, 2004 | 12:58 PM
bigkgs's Avatar
Whoa....i'm not an engineer yet
Ok...i'm not at car knowledgeable as everyone else on this thread. So could explain how one goes about resoldering? Taking out the circuit board sounds easy enough. But now i need a solder iron to fix this thing......WOW----WAY OVER MY ABILITIES....lol
Any links on how to solder or resolder?
Old Sep 10, 2004 | 01:29 PM
kachorknik's Avatar
Door Lock Timer step-by-step removal/repair
I forgot who sent me this, but somebody should post it in the FAQs. I ended up resoldering all the solder points (might as well since you went through the trouble of removing the PCB) It works like a charm!!!
http://65.65.104.211/cars/maxima/re...ockTimerBox.htm
Kachorknik!
Old Sep 10, 2004 | 01:38 PM
Kachorknik!
that link is very nice, but it's also posted a couple posts earlier in this thread
bigkgs - if you've never soldered, you may not want to start by messing around with this. You can burn up lots of different components or the circuit board itself if you're not careful. I'd recommend contacting Matt93se, you can send him the board and he'll take care of it for a small fee.
Old Sep 10, 2004 | 01:53 PM
maximagxe90's Avatar
hi,
the link still don't work,
Old Sep 10, 2004 | 05:18 PM
DaWifey's90's Avatar
what can my max do for me
alert!!!!!
uh...what's a door lock timer?
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
