Bad Ground?
Old Aug 25, 2004 | 12:09 PM
deshlock's Avatar
Bad Ground?
Ok here's my problem, I have a 94 maxima se, and it runs great. But whenever i rev the engine or really get on the gas going down the road my lights get real bright and my radio goes off completely. Ive had the battery and alternator tested and its fine. I was thinking that there might be a bad ground wire somewhere that isnt connected or is loose oor something. Does anyone have any idea's
Old Aug 25, 2004 | 12:16 PM
mtcookson's Avatar
when that happened to me (radio kept shutting off) turned out the voltage regulator. the alternator was pushing out 18 volts or so. that seems weird that the voltage regulator wouldn't be case if the lights get bright and the radio shuts off.
Old Aug 25, 2004 | 08:01 PM
deshlock's Avatar
I did have the alternator check and it didnt push out more than 14 volts so i think that it should be fine, not sure how to check the voltage regulator though. Dont really know if that could be the cause.
Old Aug 25, 2004 | 10:54 PM
smokyman13
so is it only when the pedal is to the floor? does it go away once you let go of the gas...once you slow down...after 30secs of not flooring the gas....or what...be a little more specifc on when the problems comes...goes, and how long it last, and also what is being operated or what you do at the time...
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
