Overdrive goes in and out! HELP!!
Old Aug 27, 2004 | 04:55 AM
90&91max's Avatar
My 91 w/automatic can't seem to decide if it wants to be in overdrive or not! On a slight grade at 55 to 65 it will constantly shift in and out of overdrive. If I let of the gas or give it more, it will stop for a while. I have a '90 parts car with a broke trans that I could use to swap out parts with. I just dont know what to swap! Thanks for your help!
Old Aug 27, 2004 | 09:10 AM
smokyman13
There is a button on the shifter....make sure it is off and the light is on when you dont wanna feel the shift shocks of the tranny going from OD to a gear.....if it s off..the light is on...and it still does it......then maybe there are some worn bands in the tranny
Old Aug 27, 2004 | 09:13 AM
DanNY's Avatar
Ad·min·is·tra·tor
when was the last time fluid was changed?
check to see if the fluid is low.
your TPS is ok right?
Old Aug 27, 2004 | 01:45 PM
90&91max's Avatar
Fluid was changed a few thousand miles ago. Not sure what the tps is? Throttle position switch? What effect does this have and how do you adjust it?
Old Aug 27, 2004 | 01:48 PM
DanNY's Avatar
Ad·min·is·tra·tor
ok then check fluid level...make sure it's at the right level.
throttle position sensor...it doesn't go bad much. but how much gas u give will determine if the car should downshift or not.
Old Aug 27, 2004 | 02:02 PM
maximase86's Avatar
I love lamp.
I wonder if the fluid level maybe overfilled? I had a similar problem on my 88 ranger. The fluid was overfilled and it caused it to have the same problem....but eventuually the overdrive stop working. I would check it ASAP if I were you.
S
MarcJD
Jan 19, 2005 11:32 PM
seth_js
Jul 16, 2001 05:03 PM
axion
Jan 6, 2001 11:42 AM
timmyl
Oct 11, 2000 04:58 PM
Cumalot
Oct 9, 2000 06:04 PM
