wire in trunk
Old Aug 31, 2004 | 03:43 PM
phatmax213's Avatar
wire in trunk
i just replaced my trunk lid the other day, and in order to get the new one out (and the old one) i had to cut the wire that leads to the lock. ( i figured i would splice it later.) What i was thinking was that it would control the trunk switch by the drivers seat. But without thinking, i pushed the switch and it opened. I was shocked. So my question is what does the wire control.
Old Aug 31, 2004 | 04:54 PM
Michael's Avatar
Back in a 3rd Gen.
alarm wire or 3rd brake light if its an SE trunk. Is you security light blinking all the time?
and you can get the trunk off without cutting the wires. You just have to undo the connectors under the felt trim.
Old Aug 31, 2004 | 05:22 PM
phatmax213's Avatar
no, the security light is not blinking and its a gxe trunk
btw, The guy at the junk yard cut the wire before i got to it
Old Sep 1, 2004 | 12:06 PM
DennisMik's Avatar
My 94 gxe has a wire harness running up the driver's side hinge to the lights on the back panel of the trunk lid. The plugs are at the light bulbs ends, there is no plug by the trunk hinge.
Old Sep 1, 2004 | 01:20 PM
MAXI's Avatar
are they thin wires???? if it is, it could be the security sensor for the trunk key.
Old Sep 1, 2004 | 01:27 PM
DMad8724's Avatar
its the sensor that tells to the alarm to disengage after its opened with the key, set your alarm and open the trunk with the key and it'll go off, my little sensor thing is broken
Old Aug 27, 2013 | 06:09 AM
Melissa Mullen's Avatar
Trunk lock broke
When I bought my 97maxima someone broke into it and stole the radial and broke out the trunk lock. So I got this car pretty cheap. The alarm used to work fine till I gave someone a ride and he put his bike in the trunk and tied the trunk shut by the wires coming out of the trunk lock itself. So that two wires are now hanging there losely. And my car alarm doesn't work at all. My question is where do I put the wires back so my alarm will work.
Old Aug 28, 2013 | 12:37 AM
Hectic's Avatar
You have a 4th gen, head over to that section and you'll have a better chance of getting an answer. And tell the guy with the bike that he's an idiot.
Old Aug 28, 2013 | 02:13 AM
Fakie J Farkerton's Avatar
2004 bump..wow.
Post here:
http://forums.maxima.org/4th-generat...e-posting.html
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
