summer time oil
Old Sep 2, 2004 | 10:46 AM
n1_saxman's Avatar
summer time oil
What is the best weight of oil to use in the summer?
Old Sep 2, 2004 | 10:59 AM
internetautomar's Avatar
mod or sell?
5w30
Old Sep 2, 2004 | 01:24 PM
n1_saxman's Avatar
what is the comarison between 5w30 and 10w30?
Old Sep 2, 2004 | 01:25 PM
Jeff92se's Avatar
I'm needing a caw
Why you wanna know about summer oil on Sept 2???
Old Sep 4, 2004 | 01:38 AM
n1_saxman's Avatar
uummmmmmmmmmmmm, for next year. It's still pretty hot over here and my car is giving some funny sounds the hotter it gets so I am trying to narrow it down. I am running 10W40, but was curious if anyone ran 20w50 or something that doesn't break down so quickly
Old Sep 4, 2004 | 02:22 AM
Bman's Avatar
Break down? How often are you changing your oil? This isn't an issue unless you're getting a lot of oil contamination or running your oil way too long. You shouldn't need to run some really thick oil like 20w50 unless you're intentionally masking problems. If your 10w40 is really old too it's less stable than 10w30 because of the viscosity spread.
Old Sep 4, 2004 | 07:10 AM
Cliff Clavin's Avatar
Way out West
There is a forum for fluids and lubricants here on the .org.
I change my oil about every 6 months and I only drive about 1500 miles a year. A bit of overkill, but I put in 10w30 for the summer (I live in the desert) and 5w30 for the rest of the year, but I had put in the thinner 5w30 only recently because my VTCs were ticking pretty bad.
Usually 10w30 is fine for both summer and winter. IIRC, you should go with 10w30 if temperatures frequently rise about 100 degrees, which they probably do in Utah. You should also go with a thinner oil like 5w30 or some synthetic in the winter, since I know it gets hella cold there, too...
I believe there is information about this stuff in the owner's manual of your car, too.
Cotozic
Jun 28, 2017 08:01 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
homeyclaus
Sep 3, 2015 06:15 PM
tnewbs
Aug 28, 2015 10:15 AM
erniel
Aug 8, 2015 09:32 AM
