new car need some advice
Hello I’m new to the maxima world. Got a 90 maxima auto for $500. I got it home after a few jumps. Changed the battery. The engine cranks a while before it starts. When it does starts it idles rough and will die after about min. If I drive the car it seems fine. It is also running really rich. I can feel and smell the gas. So my first guess is spark order. What is the spark order? I tried to pull a plug out but my socket hit the manifold. Is there some kind of trick? Should I use 92 octane w/o ethanol
Thank you.
Alan
Thank you.
Alan
ethanol I hear is bad for our injectors...our injectors suck anyways....since it sounds like a starting problem which would be when its cold, we can rule out the o2 sensor. try checking the resitance on the injectors, and since you just bought it..give it a good tune up
sounds to me like your EGR valve is sticking open. unplug the vacuum hose going to it and see if the car idles better. If so, then it's most likely the EGR solenoid that's gone bad..
for fuel, you can use 87 in your car as long as you don't advance the timing any..
Lakersallday24
Jun 16, 2019 01:35 AM
jskirwin
Jun 8, 2016 08:49 AM
