Holey Situation: Radiator Leak
I have a small hole in my radiator, at the top near the top, anyone have any suggestions of stuff to use or do to close it up? It squirts out antifreeze. I've tried the bar's leak silver stuff you pour in but that hasn't helped. Anyone know anything I could apply to the exterior that would work? It's really annoying because it's a tiny hole.
Thanks in advance
Thanks in advance
just replace it. not much you can do on a radiator with plastic tanks. I've tried everything in the past.. fiberglass, JB weld, plastic weld (actualy heating it and melting in new plastic).. nothing works...
just make sure you keep it full and leave the radiator cap on the first notch for the time being.. it'll keep from building too much pressure in the system until you can get the radiator replaced. just keep a couple gallons of water in the car and make sure to fill it up past the point where it's leaking every time you sit long enough for the car to cool off.
Thanks in advance
Thanks in advance
litch
123
01-04-2024 07:01 PM
Unclejunebug
04-02-2016 05:42 AM
