Engine Mounts/wheel Sensor Circuit
Old Sep 16, 2004 | 01:12 PM
OBEEWON's Avatar
My car recently fell off its jack (i know i need jack stands but this was just going to be a quick job), with the front passenger side wheel off, breaking at least one engine mount. the left(when facing the car) side of the engine heaves up when i accellerate really hard in reverse and makes a loud clack in the driver side front wheel area. now i know there are three engine mounts (i have a VE). im wondering if all three mounts are bad and if i should replace all of them, or could i get away with doing just the one seeing as tho im broke right now. i was also wondering if they make poly urethane engine mounts for our generation. if so could someone let me know where i could get some for a good price?
one more question. i keep getting this abs code for my drivers side wheel sensor circuit. i just had the spindle replaced on this. im wondering if the circuit wasnt hooked up correctly. the abs light comes on at about 6 mph, the time when abs turns on. any help would really be apreciated.
Old Sep 16, 2004 | 01:16 PM
Jeff92se's Avatar
I'm needing a caw
I'm glad you're not a pancake right now. Sheesh, get some stands. Cost of stands < 3000lbs on your legs and whatever broken parts.
You have only 2 motor mounts + 2 tranny mounts. You just have to take a close look and see if they are ripped/broken.
ABS. Whomever worked on it probably damaged the sensor wires. It could be just dirty but not fully put back but I'm 85% sure that wheel's sensor is damaged. Bone yard time.
Old Sep 16, 2004 | 01:17 PM
OBEEWON's Avatar
oh yeah i have a 5 spd VE
Old Sep 16, 2004 | 01:29 PM
OBEEWON's Avatar
do you know if they make polyurethane mounts for our gen. im thinking i might as well invest in those cus im an avid goer.
Old Sep 16, 2004 | 01:31 PM
OBEEWON's Avatar
should i get the sensor or the whole circuit?
Old Sep 16, 2004 | 01:33 PM
Jeff92se's Avatar
I'm needing a caw
They don't make mounts. You have to make your own. Sensor. You need another whole sensor and wire. They are not seperate.
mvm062
Nov 30, 2020 09:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
03VQMAX
Sep 5, 2015 03:47 PM
dcardello
Sep 3, 2015 11:44 PM
