firewall?
Old Sep 16, 2004 | 09:01 PM
chrgdRapa's Avatar
firewall?
faq doesnt work, so im just making a post now. where is the firewall located at? ive never ran a wire through it before so i dont really know. i have an intense urge to put in my new foglights right now at 9pm when its dark outside.
pfthanks
Old Sep 16, 2004 | 09:17 PM
GRNMAXDMON's Avatar
its what separates ur engine bay from ur interior. just get on ur back or just crouch down where ur gas pedal and brake pedal r and just look straight under ur steering wheel. that dark area under ur steering wheel facing u is ur fire wall. if u go to ur engine bay it also holds ur brake master cylinder and other components in place. that should answer ur question.
Old Sep 16, 2004 | 10:03 PM
chrgdRapa's Avatar
thank you, but i asked wrong, i know what firewall is, what i meant was, where is the hole in the firewall to run the wires through, im just trying to run a couple wires and a little fuse holder through so i can install my switch.
just need to know the location of that hole. is it on far right side right behind the main fuse block? or where? does it go straight through or will wires have to create an S curve to go through?
once again, thanks
Old Sep 16, 2004 | 10:07 PM
subs1000w's Avatar
best bet is to drill a hole next to the brake booster
there is a large rubber gromet that the main engine room harness goes through and its in the drivers side wheel well behind the splash gaurd. if you use this just be very carful not to hit any of the curent wires running through it or youll be screwed
Old Sep 16, 2004 | 10:13 PM
chrgdRapa's Avatar
i know i seem like a newb, so i wont try to make reputation here any better by asking the smart questions. lol
.. where's the brake booster? where should be hole be drilled and how big is the maximum diameter for drilling a hole without letting in too much engine noise in? maybe wrapping it around with something would do the trick?
Old Sep 16, 2004 | 10:50 PM
subs1000w's Avatar
this is a picture of the brake booster
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
i went just the the left of this and drilled a 1/2in holse but i was running 4ga throught so if your just running some small wires you could drill a smaller hole
just rap electric tape around the wires that go throught the hole so it kind of seals up the hole and doesnt short out the wires
Old Sep 17, 2004 | 01:07 AM
MrGone's Avatar
hood release grommet in the inner fender
depending on what the wire is for I'll help out (Vince knows how to aswell, he and I install stereo stuff the same way ).
Old Sep 17, 2004 | 04:22 AM
bhunter's Avatar
Any new hole through bare metal should have a new rubber grommet installed that fits tight in the hole with just enough room left in the center for the wires. The metal will eventually cut through tape unless it is REALLY thick.
Old Sep 17, 2004 | 05:09 AM
MrGone's Avatar
yeap.
Thats why a prefer the hood release cable grommet, just easier.
Old Sep 17, 2004 | 10:22 AM
chrgdRapa's Avatar
**** does that grommet for hood release go into the left fender? how is that easier? would i have to take off the whole fender to run it through
Old Sep 17, 2004 | 02:25 PM
subs1000w's Avatar
no you just have to remove the plastic splash gaurdesr
Old Sep 18, 2004 | 01:40 PM
chrgdRapa's Avatar
allright, got it done last night! i can literaly drive without headlights now, lol
fastcarny
Oct 12, 2015 07:06 AM
schmellyfart
Sep 25, 2015 04:47 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
