power steering removal question
Old Sep 19, 2004 | 04:22 PM
k-reg92's Avatar
i need any information regarding permanent removal . i know the older hot rods have kits to do so and im sure the max dose not so any kind of pully diagram would help or if any one has done this there info would help i drive a 92 gxe also i dont feel like explaining why i am doing this becuase it dosent matter any help is apreciated thanks
Old Sep 19, 2004 | 05:53 PM
internetautomar's Avatar
mod or sell?
this is a case of if you don't know how then DON'T!!
and if you do , I pray to g-d that you get arrested for driving an unsafe vehicle
Old Sep 19, 2004 | 06:13 PM
ntjoe's Avatar
Do you have any idea how hard that thing will be to steer? internetautomar is right, that will be so unsafe you risk yourself and others on the road.
If you looking for extra HP, look elsewhere, please. Its not worth it.
Good Luck.
Old Sep 19, 2004 | 09:51 PM
k-reg92's Avatar
its not unsafe the power steering is all rdy going out and is tought to turn only at extremly low speeds any thing over 15 mph is normal. the powersteering has been giving me problems and i like the way it feels as is but just want to rid my self of p/s all together as the whining is horrid is there a seperat belt running from p/s to crank? so i could just remove it or dose it share a comon belt with other accesory's? doing under drive pullys on the max almots seems impossible with out dropping the engine. is dropping the engine needed to do any work pully side? more conserned with handeling then hp on the p/s since it takes hardly any belt speed to turn when functioning properly thanks for the concern :: also im just needing to remove the pump not the whole steering mechanisim:::
iflexsteel
Sep 15, 2015 03:37 AM
magneto112
Sep 10, 2015 12:52 AM
hydriplex
Aug 28, 2015 02:13 PM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
