cold air intake adaptor
Old Sep 19, 2004 | 05:32 PM
jrodmaxima13's Avatar
I was informed by a local shop that they do not make a cold air intake system for the SOHC motor because it already has the tubing. They said that there is an adaptor for it to change out the stock airbox into a cone filter if anyone is familiar with this and knows where i can get a good adaptor and if it comes with something to move the MAS with. Any help would be greatful.
Old Sep 19, 2004 | 06:05 PM
95turbo gxe's Avatar
ok Ebay has the adaptor. You can get them for like less than $10 bucks. I think jeff92se also sells them I cant remember if he does or not. IIRC place air make a whole cold air kit for the vg30e too. But its kinda high.Or you could do like some of us has done make your on kit less than $40 in parts. And Ive heard that the 92 accord kit would work with some mods to it.
Old Sep 19, 2004 | 08:20 PM
Mizeree_X's Avatar
Getting back to his roots
Warpspeed also makes a cold air intake for the VG (SOHC).
Old Sep 19, 2004 | 09:41 PM
unsprung's Avatar
You can get a MAF adaptor & cone filter to make a popcharger / hot air intake. To make a CAI, you need an additional pipe that will place the filter right inside the driver-side fender along with the adaptor & cone filter.
There are many sellers on eBay who sell the adapter & cone filter for the popcharger setup. For a CAI, you can either order one from Warpspeed Performance or try one of the hybrid solutions (Accord or Eclipse CAI w/ some minor cutting).
Old Sep 19, 2004 | 10:21 PM
AscendantMax's Avatar
Be VERY careful with those ebay MAF adapters that claim it'll fit 3rd generation maximas. I bought one of them, and it did not fit at all. So it's pretty much a fancy paperweight right now. I got mine from Jeff92se when he was making them awhile back. Don't know if he still does or not.
Old Sep 20, 2004 | 07:16 AM
k-reg92's Avatar
i bought a carbuerator outlet plate for the tube that runs from carb cover to fenderwell it has a 3 inch outlet just angle it diagonaly and use 2 bolts and nuts and bolt it to ur existing maf. worked fine with a k&n cone filter. the adapter plate cost me about 3 dollars bolts and nuts were bought from lowes. hope it helps the plate was bought from autozone only color u can get them in is grey
Old Sep 20, 2004 | 08:00 AM
internetautomar's Avatar
mod or sell?
Carb outlet plate?
you got any pics , because to me this doesn't sound right
Old Sep 20, 2004 | 09:12 AM
thumpyls's Avatar
93 accord cold air will probably fit ur budget better than the 200 + cold air from ws..
Old Sep 20, 2004 | 09:40 AM
thanks
thanks for all of the replies guys i appreciate it i think i will go with one of the adaptors on ebay. see how that pans out. I was really impressed with all of the feedback this is my first post on this site.
Old Sep 20, 2004 | 10:10 AM
thumpyls's Avatar
along with the filter(pop charger) ull need the plate and 4 screws to fit the bolts..
Old Sep 20, 2004 | 12:11 PM
icepick's Avatar
I'm homosexual
Old Sep 20, 2004 | 12:49 PM
unsprung's Avatar
Yep... I bought mine from eBay & they sent me an adaptor for a 300zx. I read that some just drilled the holes in the adaptor to make it fit but when I matched it with my MAF, it was just too short.
However, upon rotating it 45 degrees, it seems to fit, though only with 2 bolts holding it on diagonally. I've seen one other do the same thing & it seems strong enough for now.
Originally Posted by icepick
I'm homosexual
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
hayne
Oct 5, 2015 11:53 AM
Dasmith
Sep 23, 2015 08:28 PM
pears
Sep 18, 2015 05:25 AM
