Gound kit again
Old Sep 23, 2004 | 02:09 PM
95turbo gxe's Avatar
Gound kit again
Ok Well search does work so hey had to do it.Ok
Ok last night I started on my ground kit. I need to run a wire from the motor to the trunk anyhow for engine noise.So I said hey ill make a ground kit too.
I went from the alternator ground on frame to the engine ground and from their to the tranny ground on the frame (in4ga from engine Ground) (8ga from alternator to engine ground) and tapped that ground and on back to batt.
But what points am I missing what eles needs to be grounded.
And do i need to take the alternater direct or can I just tap the ground wire from the alternator.
ANd how much diffrance do you feel from your ground kit?
Old Sep 23, 2004 | 04:39 PM
bumpty bump
Old Sep 24, 2004 | 11:23 AM
well **** no one knows Well going to put my 5 speed in tommorow. Ill let you know how it goes
Old Sep 24, 2004 | 11:53 AM
Mizeree_X's Avatar
Getting back to his roots
How hard is it to look around your engine bay, you lazy POS? I found about 8 grounding points in my engine and it took all of 5 minutes of snooping. Christ, just buy Matt's kit if it is so hard to do a little investigating yourself.
Old Sep 25, 2004 | 02:43 PM
goon9's Avatar
Sheesh... One reason why i moved to GA was to get away from cranky north east folk.
Any engine diagram has shows all the ground points.
Old Sep 25, 2004 | 05:46 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
if you dont have the money to just get matts kit then im not sure what to tell you. There are several key grounding points but youll have to find them yourself, i do know there are a few on the manifold by the injectors two i believe and there is another one on the top manifold pass side by vtc solenoids.....but im just going to buy matts kit....
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
