Fuel injector/ignition harness replacement
Hello, everyone!
I recently found out my 89 Max GXE is sometimes rough at runnning. A mechanic said it's the fuel injectors/ignition harness (don't know the exact name - the one with wires going into the engine from thick harness tube ). I went to a dealership, the harness for all 6 cylinders is like 60 bucks, but the service dpt. said it will cost about 300 bucks to replace it , they said it's a pain to do, that's why it's expensive. Also, I've been told that no-one other than the delaership will accept the job on doing this.
So, did anyone replace it himself? Did anyone take it to the dealer? Is the dealer honest?
Thanks for your attention.
true.. it will take a med-high level tech cause ur dealing with fuel..also ull have to replace the gaskets on the intake manifold..good price on the harness..thinking of doing mines.. what test did he do?did u try pulling the plug wires one at a time?..that labor rate is not that bad for the job. shop around
Yes it is a B1@+H to replace. It took about 2 days to do on my own working about 4 hours a day. Replacing the manifold gasket is the worst part. removing the fuel injectors is pretty bad too. if your gonna do it yourself you might wanna check out those injectors while your at it. They suck.
Thanks guys, that's what I suspected. The diagnistic is pretty simple - the wire is loose on the connector, so when you move it a little, the roughness would go away. Maybe I'll try to look at the connector itself... Who knows... Is there a way to replace just the connector (plastic plug)? I guess I could get the harness for 3 cylinders (they come in one package) and get the plug from there
Originally Posted by blacks92seAuto
hmm maybe splicing an old connector onto it and cut the old one off....if your good with soldering and wires???
Did anyone have experience on working on those wires? I'll try to solder it later...
Originally Posted by DanNY
front 3 injector is just a harness with a plug at the end.
the rear 3 is part of the MAIN harness...$$$$
Is it worth it to even try to fix it by checking the wires at the connector and soldering if broke?
Thanks for you reply.
Originally Posted by Spechtus
Could you please give more info? what is MAIN harness? I suspect it's the one with fuel lines...
fuel lines? fuel has no place in electric.
usually the connector gets coroded and that is what causes the problem.
vingodine
45
05-21-2016 12:46 PM
JMag90
08-25-2015 09:17 AM
homewrecker
08-24-2015 08:56 PM
