Too many minor annoyances to list... seeking advice on where to look
Old Sep 26, 2004 | 12:32 AM
unsprung's Avatar
Within a period of 3 weeks, I've had to replace my alternator & one of the hoses for the power steering. This is alongside all the other things I've gotten replaced within the past year (tranny, water pump, radiator, etc). Now that I have minor annoyances showing up & a nagging feeling for something else to break soon (my money's on the starter as the next big item), my parents are convinced we need a new car. I, on the other hand, rather not & I'm hoping to fix the minor annoyances so they have less reason to change.
1st problem: Rough idling while in D. At a stoplight, the car vibrates while in gear & you can hear vibrations from the hood as well (not always, though). When I throw it into Neutral, it seems to quiet down. I'm thinking it's motor mounts, but those were replaced about a year ago, & I believe the hood vibrations started when I had my radiator replaced, so I'm thinking the radiator mounts could be the culprit?
2nd problem: Tranny shifting hard AND lagging btwn 1-2 & 2-3. I just rebuilt the tranny last December & now it's lagging about 2 secs for the 1-2 & 2-3 shifts. On the highway, when I change lanes & slam on the gas, the tach will rise to ~5K, linger for 1.5-2 seconds, then shift to the next gear. Tranny fluid level is fine.
3rd problem: Rear squeaking. After I had my power steering hose replaced & the tires rotated 3 days ago, the rear has started to squeak a bit when driving. I pushed down on the car on all 4 corners & the noise I heard while driving was definitely coming from the rear.
So... anyone have any solutions I should try? I rather spend a little money on the Max now than spending a few thou on an SUV.
Old Sep 26, 2004 | 07:33 AM
internetautomar's Avatar
mod or sell?
1. the rough idling is probably a low rpm miss.
2. sounds like you got a cheap rebuild, and it's failing
3. deal with #2 first, then #1 if you still want to mess with #3 then look at the bushings
Old Sep 26, 2004 | 09:14 AM
5 ltr. beater's Avatar
I hate rebuilt tranny's. I just put a used tranny from Japan in my car and I could'nt be happier. My car even pulls harder than it did with the old tranny; when the older one was running good.
Old Sep 26, 2004 | 10:58 AM
unsprung's Avatar
1. Low RPM miss? I did notice lately that I idle only at 600rpms rather than 650 from the past. Only things I've done is run 4ga wiring to my trunk, change the alternator & battery, & install a cone filter.
2. The company I took it to came highly recommended & if this is the case, that blows. I dropped $1400 on the rebuild w/ new TC only 9 months ago. The odd thing is that it's lagging (just STOPS around the 5K mark for 1-2 seconds before switching to the next gear) rather than slipping (where the engine would CONTINUE revving higher than usual before switching to the next gear).
3. I'm guessing dealing with #2 means another tranny rebuild or buying a used tranny? What's the best way to deal with #1 (IACV adjustment?)? Which bushings are likely to need replacing? I thought the squeaks might be the struts since I know they haven't been replaced for quite some time (at least I haven't replaced them since I've had the car for ~26K miles) & they might even be the original. It's just odd I didn't notice it until after the tires were rotated.
Any other ideas on what might be the cause?
Old Sep 28, 2004 | 12:28 PM
unsprung's Avatar
Bump for any other suggestions...
One thing that came to mind is if the tranny fluid might be a culprit? Guess I'm unwilling to accept the chance that the tranny might be going again so soon, but would using an additive like Luca's or flushing / draining the tranny & replacing it with Redline be a possible (temporary or otherwise) solution?
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
mpbclutch33
Dec 26, 2015 11:11 AM
