Seeing discharges through a coil pack?
Old Oct 3, 2004 | 08:11 PM
Bman's Avatar
I just changed out my spark plugs not long ago. Everything went smoothly, but as I was checking things in they dying light (engine running) I noticed a little bit of light being emitted from the top of the coil pack on cylinder 5 (rear driver's side). It was not arcing, but just dim flashes that seemed to be coming from inside the coil. Very strange. When I had the rear coils out it seemed like the tops of them were filled with some kind of resin or polymer just below the connector.... am I just seeing the coil do it's thing through this filling, or should I plan on getting a new coil sometime in the future?
The other rear coils don't seem to do this, the car runs and idles fine, and number 5 plug did not show any signs of fouling or misfiring. All coils seemed perfectly healthy, as did all the plugs aside from being pretty worn out.
Old Oct 3, 2004 | 09:40 PM
Jeff92se's Avatar
I'm needing a caw
It's probably cracked. Looks like it's leaking voltage out the top.
Old Oct 4, 2004 | 08:21 AM
Bman's Avatar
Thanks Jeff. That's a bummer... you mean it's cracked (or otherwise damaged) internally maybe? It looked fine on the outside.
Old Oct 4, 2004 | 08:46 AM
Jeff92se's Avatar
I'm needing a caw
There might be a crack you can't see. But it's clear that there is some type of leak out of the top of the coil. I know Chris (RedMax92se) has some spares.
Old Oct 4, 2004 | 08:51 AM
«§»Craig B«§»'s Avatar
easy thing to do is take some electrical tape and wrap it around the coil pack
might work and it'll only cost you $2 for the tape so why not
Old Oct 4, 2004 | 09:29 AM
Bman's Avatar
Okay, I'll try that and see if the (internal) arcing goes away.
Jeff, you think those JDM coil packs Red92MaxSE has would be okay to use?
Thanks guys.
Old Oct 4, 2004 | 09:50 AM
Jeff92se's Avatar
I'm needing a caw
I don't know which ones he's using. I started the car with the JDM units. I used them because I figured, if they worked, they would have alot less miles on them than the ones on this old motor. Both seem to work fine. I had no problem going triple digits on the shakedown run.
Thanks guys.
Old Oct 4, 2004 | 11:05 AM
Bman's Avatar
Ha, nevermind anyway. I RE-read his FS thread, and it seems like he's keeping all his packs from what it sounds like, and currently using his JDMs.
http://forums.maxima.org/showthread.php?t=342447
Old Oct 9, 2004 | 12:43 PM
blacks92seAuto
Thanks guys.
you ever try using electrical tape around the packs yet? how did it work out? I was planning on wrapping my coil packs tight with electrical tape because i have a problem where my car "humps" while giving it gas, and sometimes it will just die. maybe i got a small crack in one of my coil packs?
Old Oct 11, 2004 | 12:09 PM
Bman's Avatar
No, sorry, not yet. I have "bigger fish to fry" but I will have to take my FSTB off again soon anyway, so I'll try and tape it up this week and see if that helps. My car possibly won't be in running condition again for a week though...
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
howardis
Dec 11, 2019 06:10 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
