QTEC Cuttout Exhaust?
Old 10-16-2004 | 10:24 AM
Duckman540i's Avatar
VE Powah!!!
http://www.quicktimeperformance.com/QTEC/ Just wondering if anyone here has any experience with it. Does it have any long time problems such as Exhaust leaks out of the valve? Does it make the fuel run alot richer? & want to know if theres any way you can fit/weld it to a Cattman or WSP Y-Pipe, Without having to use their Y-Pipe? Is there noticable HP Gains? Last Question: Does it sound really good on a VE30DE? Thanks For THe Help
Old 10-16-2004 | 10:27 AM
mtcookson's Avatar
if you aren't boosted or pushing crap loads of power there's really no need for it.
on a side note, this one seems to be good and is quite a bit cheaper. http://www.mccordcg.com/mpp/mpp.htm
Old 10-16-2004 | 10:47 AM
Aaron92SE's Avatar
NWP Engineering.com
I have the Mccord cutout that mtcookson mentioned. It's a GREAT quality product. From the reviews I've read, the QTEC and Mccord are pretty much identical in value, quality and service. I just went with Mccord b/c it was slightly cheaper.
No exhaust leaks from me. I've had mine for a while. If it does leak a little, then you goop some red RTV around the plate and it seals great. Same with the QTEC. Both companies seal great but every now and then, you might hear a very slight and quiet leak.
No, it doesn't run any richer. Your stock o2 sensor does a good job of adjusting AFR to keep it at the optimal mixture. I have a wideband air/fuel sensor and I am able to keep an eye on my AFR accurately. You won't be any richer than stock. All you are doing is letting exhaust flow much more freely, not altering the fuel system.
Yes, you need to get a 2.5" cutout from Summit Racing and then bolt the electric cutout to the cutout. I welded my cutout in my testpipe in place of my catalytic converter. Here are some pics:
Yes, there is noticable HP gains and losses. You will noticably lose some low end power. But you will gain back the top end and then some. Therefore, I shave exactly .15 in the 1/4 mile everytime I test it, open and closed, at the track. A tenth and a half is hard to notice in the butt dyno, but I can care less... it's noticable on my timeslip. That's all I care about.
Yes, this mod is worth it to me b/c I can be quiet on the street and not get any slower in the 1/4 mile. I know I have maximum flow at the track. I am able to cut 2.1 60 foots, so my low end doesn't hurt that bad b/c of my higher stall and short gearing.
Last question, yes it sounds MEAN on the VE. It will sound mean on ANY motor. The bigger the displacement, the better it should sound.
Please check out my webpage for my cutout videos that I took much effort into making:
http://www.littlebabywebs.com/maxima/videos.html
Scroll down to the Exhaust Cutout Videos section and view those two videos. They will help you determine the sound my VE Auto makes. Make sure you got your volume turned up before viewing the videos. LOL I hope I was able to answer your questions to your satisfaction.
Old 10-16-2004 | 11:36 AM
VE Powah!!!
When its shut does it have the stock sound still & will it perform as if its not there, like if I were to have a WSP Y-Pipe & Cat-Back will I still lose the Bottom End HP? I dont think it should
Old 10-16-2004 | 11:42 AM
Aaron92SE's Avatar
NWP Engineering.com
Yes, when the cutout is closed, it will perform just like you had a stock catback exhaust. It will be just as quiet as before.
But when it's open, it will be CRAZY loud and the exhaust won't get the same exhaust velocity as it did before, so you will lose a little low end power. But once that VE starts to get above 4K and flows well, you will actually gain top end and get better exhaust flow. See what I'm saying?
Do you race at the track often and want the best exhaust flow possible? Or do you just want to be loud on the streets only when you want to be?
Old 10-16-2004 | 11:44 AM
VE Powah!!!
Ya thats just it, I want it for sound mainly. A little HP gain is just a Plus.
Old 10-16-2004 | 11:48 AM
VE Powah!!!
I really want that sound @ WOT that Iron Lung has on his '97 SE, For when I get my '97 SE. Have you seen the videos of his car? Does yours sound similar when you Rev? & I know that I wont get the loopy Idle like his, cause thats from the JWT Cams
Old 10-16-2004 | 11:49 AM
Aaron92SE's Avatar
NWP Engineering.com
LOL, well you are going the right route if you want to be LOUD. Did you see my videos?
Old 10-16-2004 | 11:52 AM
Aaron92SE's Avatar
NWP Engineering.com
Yes, I saw those videos. You obviously didn't see mine that I went thru so much effort in making. Check them out. To me, it sounds just as loud at WOT as Iron Lung's car. But, of course I don't have cams.
Old 10-16-2004 | 12:02 PM
VE Powah!!!
Im still downloading yours. Im still on Dial-Up
Old 10-16-2004 | 12:14 PM
VE Powah!!!
Can it be fitted to a WSP or Cattman Y-pipe?
Old 10-16-2004 | 12:18 PM
VE Powah!!!
Nice Videos, Do you think you could make some from outside the car?
Old 10-16-2004 | 12:24 PM
Aaron92SE's Avatar
NWP Engineering.com
Sorry, I won't be able to make videos from the outside of the car. Not right now anyway.
Your 2.5" cutout can be welded anywhere that you think it can fit. I don't think you will be able to weld it in your Ypipe b/c of the lack of room. As soon as the banks come together and straighten up, you have your o2 sensor and a flex section. I got rid of my cat to make room for this. You can put your cutout after the cat, there is enough room there. But, you won't get the same gains as I did from it b/c the exhaust still has to flow through the cat.
Just get underneath your car and find out where you have about 12" of free space that you can cut and weld the cutout in.
Old 10-16-2004 | 12:35 PM
VE Powah!!!
Lets say I put it right after the Cat. Conv. But instead of Cat I put Race Pipe. Do you think it wil be almost as loud with the valve shut? Do you think it will be too loud that I will get ticketed? (thats with the full WSP 3" Exhaust & Race Pipe + Vavle Shut)
Old 10-16-2004 | 12:54 PM
Aaron92SE's Avatar
NWP Engineering.com
Maybe you don't understand the function of this device. It's very simple. When shut, your exhaust will flow through your stock exhaust the way you have it set up. With it opened, it will "dump" the exhaust out the side of the car. Of course it will be very loud.
If emissions aren't a problem, I would recommend going with the same setup as I have. Get a "race pipe" aka "Testpipe" and get a muffler shop to weld in your cutout in the testpipe.
If you have the valve open, then yes, you will get a ticket. If it's closed and you have the stock catback and stock muffler, then it will be just as quiet as stock.
Don't get a 3" exhaust until you are running lots of power with a turbo or nitrous. Just get a normal 2.5" Ypipe and 2.5" testpipe and 2.5" cutout.
Old 10-17-2004 | 10:48 AM
5 ltr. beater's Avatar
Originally Posted by Aaron92SE
Yes, I saw those videos. You obviously didn't see mine that I went thru so much effort in making. .
yeah.......shame on you duckman; Aaron had to hire a special hollywood camera crew to shoot those perfect angles of the vehicle inside and out during acceleration.
06-06-2017 02:01 PM
Justin Kroll
10-01-2015 07:03 PM
09maxshawn11
09-30-2015 10:28 AM
Socalstillen
09-26-2015 12:01 PM
TheMafia
09-04-2015 08:26 AM
Quick Reply: QTEC Cuttout Exhaust?
