Vibration on steering wheel
Old Oct 16, 2004 | 11:39 AM
fenix_jn's Avatar
Hi. Recently I had a flat tire, I replace it and all and from there the problems started: First a strange sound from the bottom of the car, recently fixed by pulling out a plastic thing over the axis but now the problem is worse, the steering wheel started to vibrate and when i turn left a noise come from the left side of the car on the driver (here is where the flat tire was). I don't know what to do. Thanks.
Old Oct 16, 2004 | 01:35 PM
sukoshiyoshi's Avatar
It could be a number of things.
1) Your rim is bent, maybe it is not too bad re-balancing could cure the problem.
2) When you had the flat maybe you tore you rack and pinion boot/CV boot and the grease is all gone.
Those are just things off the top of my head. Good luck and I sure hope that it fixes your problem.
Sukoshiyoshi
Old Oct 16, 2004 | 03:36 PM
fenix_jn's Avatar
Ok I'll try rebalancing, one more question, Can I still driving o i have to stop until i rebalance?
Old Oct 16, 2004 | 03:46 PM
jrodmaxima13's Avatar
you should be able to still drive it you may wear the tires unevenly but i would get it looked at as soon as you can i hit a curb with my stock rim and blew the crap out of my tire but it didnt bend the rim or anything was delivering pizzas at the time and was trying to look at the address of where i was going i feel pretty retarded for that
Old Oct 16, 2004 | 03:47 PM
one more thing did you use the donut for a short while before you replaced the tire and if so did it vibrate then if so then it isnt your rim it is something else
Old Oct 16, 2004 | 03:51 PM
fenix_jn's Avatar
I used the spare tire (donut??) but it was fine, only after installing the other tire then the problems started.
Old Oct 16, 2004 | 04:14 PM
xnyc's Avatar
if you replaced the tire with another one, maybe the tire size is not the same
Old Oct 16, 2004 | 04:19 PM
Greeny's Avatar
¯\(°_o)/¯
Why would wrong tire cause a vibration
Old Oct 16, 2004 | 04:24 PM
Greeny's Avatar
¯\(°_o)/¯
If you did not have a vibration before you got the flat and now you do, chances are the tire shop either did not balance the tire properly or not at all. I would take it back to them.
Old Oct 16, 2004 | 04:49 PM
Cliff Clavin's Avatar
Way out West
Most likely, your tire is out of balance. Did they give you a totally new tire, or just repair the old one? Either way, something is probably out of balance -- the tire or the rim was damaged.
My steering wheel shakes a little and I believe my rotors are warped. I don't know if this could be related or not to your problem, but I thought I'd throw it out there.
Old Oct 16, 2004 | 05:34 PM
fenix_jn's Avatar
I'll try. Thanks
Old Oct 16, 2004 | 05:42 PM
ElVito1981's Avatar
it's either that at least one of your wheels isn't balanced, or is bent. I've been in both situations.
Old Oct 16, 2004 | 11:53 PM
unsprung's Avatar
Any way to tell if your wheels are unbalanced without taking it to a shop? I recently rotated the tires last month & a few days ago, the car felt wavey when going in slow traffic on the highway. The wheels were on the rear of the car since I bought it in December 2001 & were never rotated forward until August 2004 so I'm wondering if it's a balancing issue after all the potholes I take on in NYC.
Old Nov 9, 2004 | 12:48 PM
maxcore's Avatar
maby a warped rotor...that solved my steering wheel vibration prob.
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
