90VG -> 93VG Experts Only
Old Oct 18, 2004 | 08:14 AM
90SEBlack's Avatar
Hey guys when transfering a 90VG Engine into a 93 Body that also had a VG the ECU's are the same correct? Also can i cut my injector plugs out of my 90 and wire them into the 93 since the 93 has round injector plugs and the 90 has square ones. I am pretty sure that it will not be a problem but just wanna make sure I assume as long as i use 6 of the same ones that it will not matter which ones are in the car as long as i am carefull to wire them the exact same way. Thks Guys
Old Oct 18, 2004 | 05:24 PM
MrGone's Avatar
break out the multimeter
Old Oct 18, 2004 | 05:25 PM
Bill Brasky's Avatar
Seperated at Birth?
VG30E uses the same injectors for all years. you don't need to cut anything.
and yes, you can keep the ECU and harness and well.. everything.
Old Oct 18, 2004 | 05:40 PM
emeraldmax's Avatar
no, 92-94 vg's and ve's use different style injectors than the 89-91 vg's.
Old Oct 18, 2004 | 07:07 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
if your transferring the engine why not just use the 93 injectors....
Old Oct 18, 2004 | 08:22 PM
internetautomar's Avatar
mod or sell?
Different harness
Old Oct 19, 2004 | 06:39 AM
90SEBlack's Avatar
because yes the harness is diff. and beacuse my 90 Injectors are brand new and have about 7,000 miles on them. So is the consensess that if they are both High Ohmm injectors then i should be ok.
Old Oct 19, 2004 | 07:09 AM
Matt93SE's Avatar
STFU n00b!
yes, as long as they're both the same impedance injectors then you'll be fine. swap the harness over and be sure to solder and shrink wrap the wires on them. please don't just ust butt-connectors on them. you'll have problems down the road and won't know why. (AMHIK)
Old Oct 19, 2004 | 07:14 AM
90SEBlack's Avatar
Cool will be sure to solder them Matt, After i get this swap done and workin right Im deff, stoppin bye to upgrad my undercarriage Matt I think that im gunna need the rear link kit you have beacuse i have modded my front end already and me rear end seems to dance around and cant keep up with the front.
Jon
Old Oct 19, 2004 | 07:18 AM
Matt93SE's Avatar
STFU n00b!
Let me know when your'e ready on it.
Due to the cost, I don't keep those in stock and don't order until I have money in my hand (you'd be surprised how many hundreds of times I've heard "check's in the mail!")..... So it'll take a while for me to order the parts and ship them to you. usually about 3 weeks lead time on it. just let me know.
litch
123
Jan 4, 2024 07:01 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Sep 21, 2015 12:41 PM
robtroxel
Sep 8, 2015 08:15 PM
