Daytime Running Lights
Old Oct 19, 2004 | 05:14 PM
Aggressor's Avatar
Does anyone know how to get daytime running lights on our cars? Or better yet, have it automagically turn on based on the time?
Old Oct 19, 2004 | 05:48 PM
internetautomar's Avatar
mod or sell?
how about automatically turn on based on ambient light conditions.
Old Oct 19, 2004 | 05:55 PM
Greeny's Avatar
¯\(°_o)/¯
How bout voice activation.
Old Oct 19, 2004 | 05:56 PM
Greeny's Avatar
¯\(°_o)/¯
Clap on, clap off ,clap on, clap off, the clapper!!!
Old Oct 19, 2004 | 06:00 PM
twinkle's Avatar
I want mine to know when I am thinking about wanting my lights on then turn them on....
Old Oct 19, 2004 | 07:01 PM
mod or sell?
I was serious guys , my parents car has the auto headlights as did my bonneville.
they rocked!
Old Oct 19, 2004 | 07:06 PM
Greeny's Avatar
¯\(°_o)/¯
they rocked!
Sorry...I was just having a little fun.
Old Oct 19, 2004 | 07:09 PM
Grizbone's Avatar
technically you could splice the power wire into a constant power source that only turns on when the car is running. Your headlights would then come on when starting the car and just always be on.
Old Oct 19, 2004 | 07:46 PM
Aggressor's Avatar
how about using a reduced-power of the high beams? isn't there some sort of relay that i could just drop in the relay boxes to make it work? if there isn't i'll just see if i can splice the power wire... any suggestions where to tap it from?
Old Oct 19, 2004 | 08:26 PM
Maxininct's Avatar
lolololololol.....mygreen and twinkle hehehe. im dyin here still, sorry...
Old Oct 19, 2004 | 09:44 PM
Cliff Clavin's Avatar
Way out West
just find information on the GM ones. There is bound to be some kind of relay that they use for this. Call a GM dealer and ask the service guy. If the cost is high at the dealer, maybe ask to look at the relay and where it is located. Then go to a bone yard and find the part for your car.
IIRC, some cars have auto headlights, which will come on at dark. I think I rented a Corolla with this feature. Maybe you want that, too?
Old Oct 19, 2004 | 11:13 PM
xMaxed90x's Avatar
Or when it gets dark you can just turn the headlights on... or when it is light out the same option is available....lights that turn on for you is for lazy people or for those w\ fancy cars...not a 3rd Gen Maxima
Old Oct 20, 2004 | 06:11 AM
mod or sell?
an 00 malibu is a fancy car
Old Oct 20, 2004 | 12:14 PM
shvelle's Avatar
All Canadian Max's have DRL's. Look in the FSM and see if it says anything about it. If it does, and it's a module you need, I'll give you one from my silver car - nc (shipping tho).
If you want your lights to be a little fancier like the GM ones (twilight sentinel) then I would suggest a little research on a GM forum (Caddy is probably your best bet cause the older guys are die-hards and they know their cars well), or go to the wreckers and start poking around.
Old Oct 20, 2004 | 02:17 PM
Maroon'dMaxSE's Avatar
dei got this auto headlight kit on ebay....cheq it out
Old Oct 20, 2004 | 07:04 PM
Aggressor's Avatar
shvelle: I might actually take u up on that... My car is from BC & I live in Brampton so I'm pretty sure it has DRLs in there somewhere... I guess its not working... Where do I find the DRL module?
Old Oct 20, 2004 | 07:42 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
your talking about a photocell you probably could recess it into the top part of the dash and wire it to the lights switch via relay...then at dusk the headlights would come on however you will probably need one with a time delay so bright lights dont turn your headlights off....
Old Oct 21, 2004 | 06:59 AM
shvelle's Avatar
I don't know where it is off hand, but I could check the FSM and Haynes manual for it's location (later)? I know there's a sun sensor on the top right of the dash, at the end of the defrost vent, but I think that's for the climate control. So I would assume there's a relay or somthin under the dash near the fuse panel.
Aggressor: You want it, and we can find it, you can have it.
Old Oct 22, 2004 | 02:31 AM
nismobaron's Avatar
I'm sure the DRL is similar to GM & Volvo in that they operate when car running, they don't come on with low light levels (4th gen Japanese Max's - Cefiro's - have that function). The DRL is largely Canadian only - must be a Federal Law. The wiring diagram is in the Haynes Manual.
Old Oct 22, 2004 | 09:32 AM
Aggressor's Avatar
Yep... Federal law for >1990 (i think) vehicles. I have the wiring diagram for it but I don't know where the DRL controller is... I can test it once I find it...
Old Oct 31, 2004 | 09:16 PM
RyderMax's Avatar
Ahh, but I know where it is!
[pause for critical delay]
It's under the steering column behind the plastic molding - just above your shins when you are driving.
If you have a Canadian vehicle, you should have DRLs. However, the relays and some of the transistors in the DRL unit degrade after time, and the DRLs stop working. $180CDN gets you a new DRL unit from Nissan.
Old Nov 1, 2004 | 07:45 AM
Maxzilla91's Avatar
mine stopped working.. but i like it that way
Old Nov 1, 2004 | 08:00 AM
RamJetMax's Avatar
Why do you want daytime running lights anyway? I think most insurance companies give a discount, but other than that, why go through all the trouble?
Old Nov 1, 2004 | 09:44 AM
unsprung's Avatar
Depending on how much effort & expense it'll be, sometimes the insurance discount will really result in a (bi)annual savings. When I helped my girlfriend buy a Rav4 earlier this year, the DRLs only ran ~$38 more & she gets a $30 discount on her insurance every 6 months. It's not much, but that's a recurring discount.
The idea I had in mind was to install angel eyes on my E36s (if I ever get around to it) & have those on the entire time. I doubt they would be considered DRLs though.
Old Nov 1, 2004 | 01:26 PM
Kikcaffine's Avatar
auto lights, gheyness!
tsi6001
Oct 3, 2022 10:23 PM
rtirbany
Sep 8, 2015 11:46 AM
Jeffesernia11
Aug 23, 2015 06:09 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
