Id10t light
Old Oct 20, 2004 | 04:52 AM
Putergeek's Avatar
Id10t light
Hey my airbag light came on, and stayed on, also it reset my radio, as well as killed my clock, the AC unit still works, and all the relevent fuses apear to be good working order. Any help in the matter would be greatly appriciated as i will not be driving the car again unles to the shop till i get the airbag working again.
thanks in adavance guys
-Jeb
Old Oct 20, 2004 | 09:58 AM
jrodmaxima13's Avatar
Take It To The Shop For Something Like That I Would Say Airbags Are Pains In The *** From What I Hear. What You Can Try Doing Is Resetting The Computer By Unhooking The Battery For 20 Minutes Or So Then Rehooking It Back Up That May Clear The Code Off
Old Oct 20, 2004 | 10:22 AM
Jeff92se's Avatar
I'm needing a caw
Please don't try to use all CAPS when posting. Thanks.
Your battery might be very low. Make sure it's not going dead
Old Oct 20, 2004 | 10:26 AM
my bad with the caps im at work and this program i use requires all caps and i neglected to take them off sorry
Old Oct 20, 2004 | 11:02 AM
Greeny's Avatar
¯\(°_o)/¯
I know how you feel there. I have a program at work like that too.
Old Oct 20, 2004 | 03:18 PM
Putergeek's Avatar
Well i have discovered new info on the issue the fuse was unlreated, at least the name on the fuse box on the iside was, I had a spare so i changed it, and it all worked, however with in an hour the fuze had blown again..., mind you the car was off for this hour, and i went to run errands when i discovered the blown fuse again. It is raining, this issue didn't start till yesturday when the rain came, and car was parked with the front slightly eleveted due to the incline of my driveway. I am thinking that some water some how got in somewhere that it shouldn't. But has nothing has gone wrong with the car since i bought it, i know nothing about it, b/c i have had nothing to fix. Which is a testment to the car. However this is still a perplexing issue, again guys any help would be greatly welcome.
Old Oct 20, 2004 | 03:23 PM
«§»Craig B«§»'s Avatar
check my site, there is a listing of what each fuse controls
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
