problems with door locks...
Old Oct 23, 2004 | 09:14 AM
MaXtUneD's Avatar
This only happens sometimes..off and on kind of thing..
Problem 1:
When I open the doors from the inside, I turn the ket to open the driver side then turn it again to open all doors, but when I do this, then all the door will lock..If i do the same process, it still happens..
Problem 2:
After driving, i get out of the door, then I press the lock button on the door panel, but it wont lock the doors. Sometimes, I can open all doors from the inside with the panel button on the driver door, but when I open my door and get out, I cant lock it with the button..
What Do I hae to fix??
PS: I am most likely sure this is in the stickies or it has been discussed before...Too lazy, also I cant search...
Old Oct 23, 2004 | 06:16 PM
bhunter's Avatar
Take out your door lock timer which is inside the panel on the driver's side. It is on the right side of the steering column and has two wiring harnesses going into it. Mainly it needs to be resoldered around where the relay is on the circuit board. It would be a good idea to get a good magnifier and inspect all the solder connections and resolder any that look fractured.(cold solder joints) It is really hard to see them with the naked eye.
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
knight_yyz
Nov 6, 2015 02:34 PM
slowlifer
Sep 8, 2015 05:53 AM
