Ex Manifold studs - manifold
Old Oct 23, 2004 | 11:50 PM
Tom's Avatar
Tom
I noticed my engine would tick when cold, but gets quieter after it warmed up. Took a look at the ex manifold studs and sure enough, two of them were gone on the front. The bummer part is that I had them replaced before (well, it has been about 90K since then). I have 167k miles now.
I figured I'll do it myself this time to save some $$$.
The manifold studs, nuts and the gaskets are priced comparably from many sources, but the question I have is the manifold.
Does this need to be replaced? Last time, it was warped, hence it was replaced. If so, what's the best place to get a good deal (on-line)?
I looked around a few places, but they all show the rear side manifold in stock, but not the front.
Thanks,
Old Oct 24, 2004 | 12:02 AM
nubiannupe's Avatar
OG Maxima.org Member
Have you checked with Stillen yet? Also, look up Brian (internetautomar) and his website. He might be able to get 'em, too.
Old Oct 24, 2004 | 07:13 AM
lophix's Avatar
btw, get the studs from a turbo z....
write-up on replacing studs...
I believe those part #s are correct. WHile you have the manifold out, check to see if it's warped. It isn't too bad of a job (the fronts) I think I could get it down to 4 hrs if I did it alone. The rears on the other hand, are the biggest bi### of all. G/luck
Old Oct 24, 2004 | 07:20 AM
Cliff Clavin's Avatar
Way out West
Look in the sticky about "JDM VE engine replacement." I know you don't have a VE, but I think Jeff or Keelan put in the proper part numbers on the studs.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
dshinn
Sep 26, 2015 08:07 PM
dcam0326
Sep 26, 2015 05:20 AM
Lowered_a33
Sep 10, 2015 09:41 PM
