226k mi on VE Compression results
Old Nov 1, 2004 | 01:46 PM
3rdmaxse0's Avatar
is this alright or should I rebuild.
cyl1-150 psi cyl2-125 psi cyl3-130psi cyl4-125 psi cyl5-130 psi cyl6- 135 psi
Old Nov 1, 2004 | 01:48 PM
Jeff92se's Avatar
I'm needing a caw
I think that's within oem specs but that seems pretty low across the board. Please explain how you did the check. Might cost more to rebuild vs getting a good JDM motor. Unless you are going to do the rebuild yourself.
Old Nov 1, 2004 | 03:02 PM
Maximan190's Avatar
even if you rebuild it yourself you wind up spending more than you want to/expect to; ive been working on mine for months and its almost done... but at least you know everything that you did to the rebuilt motor and it being brand new versus a used motor with who knows what kind of condition
Old Nov 1, 2004 | 03:22 PM
subs1000w's Avatar
my jdm did 155 to 165 across the board so thats alittle low but if it runs fine dont worry about it
Old Nov 1, 2004 | 03:57 PM
3rdmaxse0's Avatar
well im buying a motor from someone on the org. with 20k on rebuilt except its a little messed up in the bottom end but i got plans and ready to order parts. been wanting to do for 2 yrs.
Old Nov 1, 2004 | 05:04 PM
dadonfromqueenz's Avatar
Dont do a rebuild! LoL. I regret doing mine. The best thing to do is to buy another one in better condition.
Old Nov 1, 2004 | 05:34 PM
3rdmaxse0's Avatar
well its not gonna be stock and im getting the motor cheap and its something to do this winter. my motor runs great hell 15.2 @93 2.44 60' isnt bad for basic bolt ons with that many miles. and its not gonna be a 3.0 anymore neither and i was thinking how different is the vg30de crank vs the ve would the sprocket fit where the pulley is or are the keyways different or is it different lengths. just wished i had both cranks and do some comparing.
Old Nov 1, 2004 | 05:39 PM
mtcookson's Avatar
did you hold the throttle wide open when doing the test and remove the all of the spark plugs before testing any of them?
Old Nov 1, 2004 | 11:25 PM
dmontzsta's Avatar
Ford Only.
Wow, my 280k VE had better compression than that.
Old Nov 3, 2004 | 02:51 PM
3rdmaxse0's Avatar
I took plugs out one at a time and didnt hold throttle down and engine was warm.
Old Nov 3, 2004 | 07:22 PM
Matt93SE's Avatar
STFU n00b!
hold the throttle on the floor when you do the compression test. I bet your numbers will jump up to 180 ish.
Old Nov 3, 2004 | 07:32 PM
3rdmaxse0's Avatar
dam i was hoping bad compression was why my car is slow.
Old Nov 3, 2004 | 07:35 PM
Matt93SE's Avatar
STFU n00b!
LOL! nope.. you're just a bad driver.
Old Nov 3, 2004 | 07:50 PM
3rdmaxse0's Avatar
oh well Ill just change heads when i get my motor or get them ported first then install em. anyways power seems better now since I rewired my Bosch o2 sensor (wires dont match color to color) saturday and reset the ecu tonight it seems to pull alot harder in 2nd from like 2500 and really kicks at 3500 but had to stop at 4200~ ish cuz im speeding in a 25. Ill find out on the highway tomorrow morning. oh well its been three years and I had it to a point that it didnt accelerate a 90 4cyl AT camry took me. then I found the ORG and well almost running perfect.
Old Nov 4, 2004 | 07:59 AM
mtcookson's Avatar
i'd also take out all of the plugs so that the engine can turn over freely but the biggest thing is to keep the throttle open like Matt said.
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
