Tranny Cooler etc..... on my new max
Old Apr 15, 2001 | 11:05 AM
ajdrums
ok I'm sure this question has been answered before but I had trouble finding it on previous posts. whats the best place to order a Tranny cooler for a 92 maxima GXE? I remember someone saying a place that honors membership here as a 20% discount. and also, how much work is involved in installing one? will I need a lift? I have worked on cars somewhat so its not like I'm mechanacally challenged.
Oh by the way I did buy that 92 GXE maxima auto transmission with 138,000 miles for $3000. I checked it out and besides a few small dents it was close to perfect working order. and according to the records the transmission fluid was changed on a regular basis and when I opened the resivor it wasn't black and lumpy but almost clear. I did notice a slight rattle at 65 when driving it home, any thoughts on that? Also, I would like to do as much preventative maintence as possible any suggestions? should I have the tranny flushed right away and have a tune up? what brands should I use for distributer, plugs, wires, air filter, oil filter etc... what type of oil should I use? What octane gas? one other thing, the power door locks seem to stop working once in awhile. I pressed the button, and it sounded like a relay clicked, but the locks didn't do anything. I waited a little while and tried again and they worked fine. thans so much for your help I love the car already.
Old Apr 15, 2001 | 03:30 PM
Cincy94Max's Avatar
The 25% discount is for Courtesy Nissan in Texas http://www.courtesyparts.com . I don't know if they sell tranny coolers but the general consensus on the boards is Hayden tranny coolers are the way to go. I believe they are available at your local Pep Boys. As for the distributor, et cetera, I would buy from Courtesy Nissan, which sells OEM replacement parts at a 25% discount to Maxima.org members. For gas, the manual for my 94 GXE says 91 octane is recommended but 89 is acceptable. Personally I put 93 in because the motor has 132,000 miles and I don't wanna mess around with the knocking. Which power door lock switch doesn't work sometimes?
Old Apr 15, 2001 | 05:43 PM
brubenstein's Avatar
I don't know where you checked your transmission fluid, but there is no resevoir. Transmission fluid should be clear and red.
I used a B&M cooler (model 70255), which has a better design than the Haydens. I got it from Jegs for about $50 with shipping. If the fluid is in good shape wait a year before changing it.
Old Apr 15, 2001 | 08:14 PM
Brian_TII's Avatar
Maybe the power steering? It is typically clear fluid and it has a resevoir...
Old Apr 18, 2001 | 09:07 PM
ajdrums
your right I realized its the power steering fluid. I've been driving the max around a bit unregestered and I am already in love!!! it beats the hell out of my 1989 Dodge Colt! I paid 3k and it had 138k on it, but it is in almost perfect condition...I made out like a bandit. I just need to fix the door locks. None of them work now. I press the lock/unlock button and I hear a relay in the dashboard but nothing happens. Also if I try the keypad to unlock the same thing happens. any ideas???
thanks for the help
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
Quickywd01
Sep 21, 2016 09:36 PM
maxima297
Sep 30, 2015 03:32 PM
jds22
Sep 29, 2015 02:03 PM
