Ok I got a block heater now what?
Old Nov 1, 2004 | 04:48 PM
Hemphire's Avatar
I purchased a new block heater and have no idea how to install it. I'm told that you have to remove one of the frost plugs. What is the best way to remove one of these? I'm told that you have to punch it out. Well if I do that wont the plug end uip in the block? Now that would suck *** if that happend. What would you guys sugest for taking one of the frost plugs out?
Old Nov 2, 2004 | 01:46 AM
lubricity's Avatar
It isn't a diesel. Put good oil in it and don't worry
Old Nov 2, 2004 | 06:32 AM
DanNY's Avatar
Ad·min·is·tra·tor
did the NEW block heater not come w/ instructions on installation?
it depends on what kind of heater you have. some dips into the oil..some goes on like a heating pad.
Old Nov 2, 2004 | 11:58 AM
Hemphire's Avatar
This one that I got gets pluged into one of the frost plugs. All it says is to punch the plug out. I'm just worried about having the metal plug fall inside.
Old Nov 2, 2004 | 12:58 PM
DanNY's Avatar
Ad·min·is·tra·tor
it's called FREEZE plug. there's one on each side (maybe more). it's a metal cup (almost) that's really a plug. i don't know how that heater works in getting the heating element into the freeze plug but i've never see that set up before.
you won't get metal shavings in there if you knock it out correctly....but from what i see in your writing i would return that heater and get a different one that's easier to install.
Old Nov 2, 2004 | 01:25 PM
Matt93SE's Avatar
STFU n00b!
that's actually pretty normal for these things.
there's a tool made to remove freeze plugs, but it's basically just a hook on the end of a hammer type thing. you can get them at most tool supply stores, and may be able to rent one at a parts store.
If not, then simply use a screwdriver and a hammer to punch through it, then pry it out of the block. not much to it. don't worry about it getting stuck inside the block- not going to happen. the coolant passages behind them aren't large enough for the plug to fall in.
Old Nov 2, 2004 | 03:06 PM
Hemphire's Avatar
Well I have no fear now that the great and mighty Matt93SE says it's nothing to worry about. Thanks for the posts guys.
Would you suggest one of the front plugs or rear plugs?
I have the biggest hammer in my tool boz ready to go
Old Nov 2, 2004 | 03:11 PM
Jeff92se's Avatar
I'm needing a caw
http://www.peugeotclub.org/peugeot/archive/96/0255.html
Found this. The water heater unit seems nice as you get heat inside the car instantly.
Old Nov 2, 2004 | 04:07 PM
Matt93SE's Avatar
STFU n00b!
there are some behind the timing belt, (around the water pump area), and another one or two on the back of the block.. I doubt you want to try to get to any of those.
same thing for the ones on the back of the block, simply because they're hard to get to.
soooo, your best bet is to get one on the side of the block (facing the front of the car), because they're easier to get to.
Old Nov 3, 2004 | 12:55 PM
Hemphire's Avatar
Have I ever told you guys that I love you? Well I do in a totaly platonic kind of way any way. The kind of love reserved for a loyal dog. You know what I meen. Do I sound gay now. Oh well I have allways been a happy kinda guy.
Old Nov 3, 2004 | 07:34 PM
Matt93SE's Avatar
STFU n00b!
you saying you think of us as PETS?!
I kill you, boy.
Old Nov 6, 2004 | 07:28 AM
Hemphire's Avatar
I kill you, boy.
Just dont pee on my leg
Old Nov 6, 2004 | 12:28 PM
Cliff Clavin's Avatar
Way out West
The proper term on this board is "ghey" or
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
RWCreative
Sep 21, 2015 11:01 AM
