Fuel injector Question
Old Nov 5, 2004 | 10:21 AM
Brooklyn Legend's Avatar
How can you tell if your injectors are not working? With out taking them out.
Old Nov 5, 2004 | 11:33 AM
internetautomar's Avatar
mod or sell?
unplug them one at a time to check for a change in running and Measure resistance
Old Nov 6, 2004 | 09:09 AM
usaf_hydro's Avatar
or you can do the whole screw driver to the injector trick while resting your ear on the handle and listening for clicking
Old Nov 6, 2004 | 03:40 PM
can I unplug them without opening the engine up?
Old Nov 6, 2004 | 04:37 PM
broncoguy's Avatar
I think he meant pull the plug wire and see if there is any change in the way the car runs. On a VG engine, you can't get to the injector harness without removing the intake manifold- which means the car won't be running.
Old Nov 6, 2004 | 07:34 PM
so how would I do it because I have a VG engine.
Can I rip the boot and test the plug that that is connected to the injector, or will I not get a reading that way? Also when you say unplug do you mean that the fuel injector plugs can be removed without taking out the engine cover?
Also I thought all VG30E engines were the same? but 92-94 Vg's have different fuel injectors than 89-91 why is that?
I know I ask too much but I really need the help.
thanks to those who resond.
Old Nov 7, 2004 | 07:42 AM
bumpity bump bump
Old Nov 7, 2004 | 08:04 AM
broncoguy's Avatar
1.start car
2. pull a plug wire.
3. If you notice a change in the idle, then that cylinder is firing.
4. if you don't notice a change in the idle when you pull the plug wire, then that cylinder is not firing.
Repeat process with each plug wire, pulling and replacing one at a time.
This is the easiest way to tell, without puling the intake off to get to the injector harness. If the cylinder is not firing, it's at least a 90% probability that your injector is bad (on VG's, anyway).
You will HAVE to pull the upper intake manifold off in order to replace the injectors. At that point you can verify with a meter that the injectors you suspect are bad really are bad. (they will be).
The injectors on the 92-94 cars have different plugs, which means different harness connectors. Don't know why they did it- maybe because they also had the VE engine come out in 92, and they wanted one set of injectors for both models. (No idea if this is true or not, just a guess)
Old Nov 7, 2004 | 10:47 AM
mod or sell?
VE and VG remain different. the connector changed because of internal changes to the injectors. they made them a tad bit better.
Maxboy23
55
May 1, 2025 06:09 PM
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
bumpypickle
Sep 20, 2015 08:22 AM
