Shudders at 45mph.......
Old Apr 15, 2001 | 10:52 PM
BlackMaxGoddess's Avatar
Ok, this may be showing my car ignorance, but lately my car shudders at 45mph exactly. Only when I am accelerating slowly though, not when I pick up speed quickly. Any thoughts on what it is?? Thanks in advance for any thoughts!
Old Apr 15, 2001 | 11:15 PM
fastmax92's Avatar
maybe
maybe you shoould see if your tires are out of balance..
Old Apr 15, 2001 | 11:17 PM
fastmax92's Avatar
don't you live around portland
i live in beaverton and maybe able to do this for free...just let me kno my name is kyle
Old Apr 16, 2001 | 04:16 AM
Pervis Anathema's Avatar
It sounds like your tires are out of balance. Also, you might have a bent rim. Both of my fronts were bent; Replacing them made my ride (especially at 85mph+) smooth as glass!
Old Apr 16, 2001 | 10:25 AM
Thanks!
I live in Oly, WA, about 2 hours from Portland/Beaverton I think. How much do tire places usually charge to do this sort of thing? Not that I won't keep ya in mind Kyle, just a long drive.
Old Apr 16, 2001 | 11:18 AM
brubenstein's Avatar
If the car shutters at only 45mph, and it doesn't get worse as you go faster, it has nothing to do with tires/wheels. Balance/run out problems get worse as speed goes up.
It sounds more like an engine "stumble" under load at low RPMs. When you accelerate harder, you're probably in a lower gear, and at a different RPM as you pass 45 mph.
Old Apr 16, 2001 | 01:01 PM
NYCe MaXiMa's Avatar
besides what others mentioned..
You may have a defective tire, with a lump or a "bubble" in the sidewall or the flat surface, I had this problem on 2 sets of rims, on my stock rims, 1 tire had a small, 1-2 inch bubble in the sidewall, it caused vibration you can feel in the steering wheel and gas pedal, it usually was felt around 50mph. On a set of 17's I put a pretty large lump on the inside sidewall and it caused vibration at 50-60 as well....
JMag90
Aug 25, 2015 09:17 AM
NisMax615
Feb 11, 2003 06:42 PM
Joseph77
20
Jan 25, 2003 12:23 PM
bidnizman
Aug 10, 2002 04:07 PM
SCCA Solo2
Mar 23, 2001 10:23 AM
